Datasheet MAX6220 (Analog Devices) - 3
DescriptionLow-Noise, Precision, +2.5V/+4.096V/+5V Voltage Reference
Pages / Page10 / 3 — Low-Noise, Precision, +2.5V/+4.096V/+5V. Voltage Reference. MAX6220. …
File Format / SizePDF / 791 Kb
Low-Noise, Precision, +2.5V/+4.096V/+5V. Voltage Reference. MAX6220. ELECTRICAL CHARACTERISTICS—(+4.096V). PARAMETER. SYMBOL
Low-Noise, Precision, +2.5V/+4.096V/+5V Voltage Reference MAX6220 ELECTRICAL CHARACTERISTICS—(+4.096V) PARAMETER SYMBOL
(VIN = +10V, IOUT = 0mA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS TA MIN TYP MAX UNITS
Input Voltage Range VIN 8 40 V Output Voltage VOUT +25°C 4.092 4.096 4.100 V Output VoltageTemperature TCVOUT 2 20 ppm/°C Coefficient (Note 1) +25°C 2 7 ∆V Line Regulation (Note 2) OUT/ ∆ 8V ≤ VIN ≥ 40V ppm/V VIN 45 +25°C 1 6 Sourcing: 0mA ≤ IOUT ≤ 15mA 15 ∆VOUT/ Load Regulation (Note 2) ∆ ppm/mA IOUT +25°C 1 6 Sinking: -15mA ≤ IOUT ≤ 0mA 30 +25°C 1.9 3.1 Supply Current IIN mA 3.5 Trim-Adjustment Range ∆VOUT (Figure 1) ±24 ±40 mV Turn-On Settling Time tON To ±0.01% of final value 5 µs Output Noise Voltage 0.1Hz ≤ f ≥ 10Hz 2.4 µVp-p eN (Note 3) 10Hz ≤ f ≥ 1kHz 2.0 4.0 µVRMS Temperature Hysteresis (Note 4) 20 ppm Long-Term Stability ∆VOUT ∆t = 1000hr 20 ppm
_______________________________________________________________________________________ 3
