Datasheet MAX6161, MAX6162, MAX6163, MAX6164, MAX6165, MAX6166, MAX6167, MAX6168 (Analog Devices)
DescriptionPrecision, Micropower, Low-Dropout, High-Output-Current, SO-8 Voltage References
Pages / Page17 / 1 — MAX6161–MAX6168. Precision, Micropower, Low-Dropout,. …
File Format / SizePDF / 2.7 Mb
MAX6161–MAX6168. Precision, Micropower, Low-Dropout,. High-Output-Current, SO-8 Voltage References. General Description
Datasheet MAX6161, MAX6162, MAX6163, MAX6164, MAX6165, MAX6166, MAX6167, MAX6168 Analog Devices
link to page 16 link to page 15 link to page 16
MAX6161–MAX6168 Precision, Micropower, Low-Dropout, High-Output-Current, SO-8 Voltage References General Description Benefits and Features
The MAX6161–MAX6168 are precision, low-dropout, ● ±2mV (max) Initial Accuracy micropower voltage references. These three-terminal ● 5ppm/°C (max) Temperature Coefficient devices operate with an input voltage range from (VOUT + 200mV) to 12.6V and are available with output voltage ● 5mA Source Current at 0.9mV/mA options of 1.25V, 1.8V, 2.048V, 2.5V, 3V, 4.096V, 4.5V, ● 2mA Sink Current at 2.5mV/mA and 5V. They feature a proprietary curvature-correction ● Stable with 1μF Capacitive Loads circuit and laser-trimmed thin-film resistors that result in a very low temperature coefficient of 5ppm/°C (max) and an ● No External Capacitor Required initial accuracy of ±2mV (max). Specifications apply to the ● 100μA (typ) Quiescent Supply Current extended temperature range (-40°C to +85°C). ● 200mV (max) Dropout at 1mA Load Current The MAX6161–MAX6168 typically draw only 100μA of ● Output Voltage Options: 1.25V, 1.8V, 2.048V, 2.5V, supply current and can source 5mA (4mA for MAX6161) 3V, 4.096V, 4.5V, 5V or sink 2mA of load current. Unlike conventional shunt- mode (two-terminal) references that waste supply
Applications
current and require an external resistor, these devices ● Analog-to-Digital Converters (ADCs) offer a supply current that is virtually independent ● Portable Battery-Powered Systems of the supply voltage (8μA/V variation) and do not ● Notebook Computers require an external resistor. Additionally, the internally ● PDAs, GPS, DMMs compensated devices do not require an external compensation ● Cellular Phones capacitor. Eliminating the external compensation capacitor ● Precision +3V/+5V Systems saves valuable board area in space-critical applications. A low-dropout voltage and a supply-independent, ultra-low supply current make these devices ideal for battery-
Ordering Information, Typical Operating Circuit , and
operated, high-performance, low-voltage systems.
Selector Guide appear at end of data sheet.
The MAX6161–MAX6168 are available in 8-pin SO packages.
Pin Configuration
TOP VIEW
N.C. 1 8 N.C. IN 2 7 N.C.
MAX6161– MAX6168
N.C. 3 6 OUT GND 4 5 N.C.
SO
19-1650; Rev 4; 12/08
