Datasheet MAX6192 (Analog Devices) - 3
DescriptionPrecision, Micropower, Low-Dropout Voltage References
Pages / Page14 / 3 — MAX6190–MAX6195/MAX6198. Precision, Micropower,. Low-Dropout Voltage …
File Format / SizePDF / 264 Kb
MAX6190–MAX6195/MAX6198. Precision, Micropower,. Low-Dropout Voltage References. ELECTRICAL CHARACTERISTICS—MAX6191. PARAMETER
MAX6190–MAX6195/MAX6198 Precision, Micropower, Low-Dropout Voltage References ELECTRICAL CHARACTERISTICS—MAX6191 PARAMETER
(VIN = 5V, IOUT = 0nA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
MAX6191A 2.046 2.048 2.050 Output Voltage VOUT TA = +25°C MAX6191B 2.043 2.048 2.053 V MAX6191C 2.038 2.048 2.058 MAX6191A 2 5 Output-Voltage Temperature TCVOUT MAX6191B 4 10 ppm/°C Coefficient (Note 1) MAX6191C 8 25 ΔVOUT/ Line Regulation 2.5V ≤ VIN ≤ 12.6V 10 100 µV/V ΔVIN ΔV Sourcing: 0 OUT/ ≤ IOUT ≤ 500µA 0.12 0.55 Load Regulation µV/µA ΔIOUT Sinking: -500µA ≤ IOUT ≤ 0 0.18 0.70 Short to GND 4 Short-Circuit Current ISC mA Short to IN 4 Temperature Hysteresis ΔVOUT/ 75 ppm (Note 2) cycle ΔVOUT/ ppm/ Long-Term Stability 1000hrs at +25°C 50 time 1000hrs
DYNAMIC
0.1Hz to 10Hz 40 µVP-P Noise Voltage eOUT 10Hz to 10kHz 105 µVRMS Ripple Rejection VOUT/VIN VIN = 5V ±100mV, f = 120Hz 84 dB Turn-On Settling Time tR To 0.1%, COUT = 50pF 30 µs Capacitive-Load Stability Range COUT (Note 3) 0 2.2 nF
INPUT
Supply Voltage Range VIN Guaranteed by line-regulation test 2.5 12.6 V Quiescent Supply Current IIN 27 35 µA Change in Supply Current IIN/VIN 2.5V ≤ VIN ≤ 12.6V 0.8 2 µA/V Maxim Integrated 3
