Datasheet MAX6192 (Analog Devices) - 10
Description | Precision, Micropower, Low-Dropout Voltage References |
Pages / Page | 14 / 10 — MAX6190–MAX6195/MAX6198. Precision, Micropower, Low-Dropout Voltage … |
File Format / Size | PDF / 264 Kb |
MAX6190–MAX6195/MAX6198. Precision, Micropower, Low-Dropout Voltage References
MAX6190–MAX6195/MAX6198 Precision, Micropower, Low-Dropout Voltage References Typical Operating Characteristics (continued)
(VIN = 5V for MAX6190/1/2/3/4/8, VIN = 5.5V for MAX6195; IOUT = 0nA; TA = +25°C; unless otherwise noted.) (Note 5)
MAX6190 MAX6195 POWER-SUPPLY REJECTION POWER-SUPPLY REJECTION SUPPLY CURRENT vs. FREQUENCY vs. FREQUENCY vs. INPUT VOLTAGE
100 100 40 VCC = 5.5V ±0.25V VALID OVER SPECIFIED 38 VIN (MIN) TO VIN (MAX) MAX6190 toc10 36 FOR EACH PART MAX6190 toc12 MAX16190 toc11 10 10 34 μA) 32 30 1 1 PSR (mV/V) PSR (mV/V) 28 SUPPLY CURRENT ( 26 0.1 0.1 24 22 0.01 0.01 20 100 1k 10k 100k 1M 10M 10 100 1k 10k 100k 1M 10M 2 4 6 8 10 12 14 FREQUENCY (Hz) FREQUENCY (Hz) INPUT VOLTAGE (V)
MAX6190 MAX6195 OUTPUT IMPEDANCE OUTPUT IMPEDANCE SUPPLY CURRENT vs. FREQUENCY vs. FREQUENCY vs. TEMPERATURE
1k 1k 40 MAX6190 toc13 MAX6190 toc14 MAX6190 toc15 ) Ω 100 Ω 100 35 μA) VIN = 12.5V V 10 10 30 IN = 7.5V VIN = 5.5V OUTPUT IMPEDANCE ( OUTPUT IMPEDANCE ( SUPPLY CURRENT ( 1 1 25 VIN = 2.5V (MAX6190/MAX6191 ONLY) 0.1 0.1 20 0.01 0.1 1 10 100 1k 10k 100k 1M 0.01 0.1 1 10 100 1k 10k 100k 1M -40 -20 0 20 40 60 80 100 FREQUENCY (Hz) FREQUENCY (Hz) TEMPERATURE (°C)
MAX6190 MAX6195 MAX6190 0.1Hz TO 10Hz OUTPUT NOISE 0.1Hz TO 10Hz OUTPUT NOISE TURN-ON TRANSIENT
MAX6190 toc16 MAX6190 toc17 VIN MAX6190 toc18 1V/div VOUT V 10μV/div OUT 20μV/div VOUT 1V/div 1s/div 1s/div 10μs/div 10 Maxim Integrated
