Datasheet MAX6192 (Analog Devices) - 6
DescriptionPrecision, Micropower, Low-Dropout Voltage References
Pages / Page14 / 6 — MAX6190–MAX6195/MAX6198. Precision, Micropower, Low-Dropout Voltage …
File Format / SizePDF / 264 Kb
MAX6190–MAX6195/MAX6198. Precision, Micropower, Low-Dropout Voltage References. ELECTRICAL CHARACTERISTICS—MAX6194. PARAMETER
MAX6190–MAX6195/MAX6198 Precision, Micropower, Low-Dropout Voltage References ELECTRICAL CHARACTERISTICS—MAX6194 PARAMETER
(VIN = 5V, IOUT = 0nA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS INPUT
MAX6194A 4.498 4.500 4.502 Output Voltage VOUT TA = +25°C MAX6194B 4.495 4.500 4.505 V MAX6194C 4.490 4.500 4.510 MAX6194A 2 5 Output-Voltage Temperature TCVOUT MAX6194B 4 10 ppm/°C Coefficient (Note 1) MAX6194C 8 25 ΔVOUT/ Line Regulation (VOUT + 0.2V) ≤ VIN ≤ 12.6V 25 160 µV/V ΔVIN ΔV Sourcing: 0 OUT/ ≤ IOUT ≤ 500µA 0.16 0.80 Load Regulation µV/µA ΔIOUT Sinking: -500µA ≤ IOUT ≤ 0 0.22 1.00 Dropout Voltage (Note 4) VIN - VOUT ΔVOUT ≤ 0.2%, IOUT = 500µA 100 200 mV Short to GND 4 Short-Circuit Current ISC mA Short to IN 4 Temperature Hysteresis ΔVOUT/ 75 ppm (Note 2) cycle ΔVOUT/ ppm/ Long-Term Stability 1000hrs at +25°C 50 time 1000hrs
DYNAMIC
0.1Hz to 10Hz 110 µVP-P Noise Voltage eOUT 10Hz to 10kHz 215 µVRMS Ripple Rejection VOUT/VIN VIN = 5V ±100mV, f = 120Hz 76 dB Turn-On Settling Time tR To 0.1%, COUT = 50pF 180 µs Capacitive-Load Stability Range COUT (Note 3) 0 2.2 nF
OUTPUT
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 27 35 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 0.8 2 µA/V 6 Maxim Integrated
