Datasheet VLMS1300, VLMO1300, VLMY130., VLMG1300, VLMTG1300, VLMB13 (Vishay)
ManufacturerVishay
DescriptionHighbright 0603 ChipLED
Pages / Page13 / 1 — VLMS1300, VLMO1300, VLMY130., VLMG1300, VLMTG1300, VLMB13.. Highbright …
File Format / SizePDF / 264 Kb
VLMS1300, VLMO1300, VLMY130., VLMG1300, VLMTG1300, VLMB13.. Highbright 0603 ChipLED. FEATURE. DESCRIPTION. APPLICATIONS
Datasheet VLMS1300, VLMO1300, VLMY130., VLMG1300, VLMTG1300, VLMB13 Vishay
Highbright 0603 ChipLED FEATURE
• Super thin ChipLED with exceptional brightness 1.6 mm x 0.8 mm x 0.8 mm (L x W x H) • High reliability PCB based • Wavelength (465 to 475) nm (blue), typ. 525 nm (true green), typ. 571 nm (yellow green), (584.5 to 597) nm (yellow), typ. 605 nm (soft orange), typ. 631 nm (super red) • InGaN blue available with protection diode, device type VLMB1310 with HBM 8000 V • AllnGaP and InGaN technology
DESCRIPTION
• Viewing angle: extremely wide 130° The new ChipLED series have been designed in the smallest • Grouping parameter: luminous intensity, wavelength, VF SMD package. This innovative ChipLED technology opens • Available in 8 mm tape on 7" diameter reel the way to • Compatible to IR reflow soldering • smaller products of higher performance • Preconditioning according to JEDEC® level 3 • more design in flexibility • Material categorization: for definitions of compliance • enhanced applications please see www.vishay.com/doc?99912 The 0603 LED is an obvious solution for small scale, high brightness products that are expected to work reliably in an
arduous environment. • Backlight keypads • Navigation systems
PRODUCT GROUP AND PACKAGE DATA
• Cellular phone displays • Product group: LED • Displays for industrial control systems • Package: SMD 0603 ChipLED • Miniaturized color effects • Product series: standard • Traffic displays • Angle of half intensity: ± 65°
PARTS TABLE LUMINOUS FORWARD WAVELENGTH INTENSITY at I VOLTAGE at I PART COLOR F (nm) at IF F (mcd) TECHNOLOGY (mA) (mA) (V) (mA) MIN. TYP. MAX. MIN. TYP. MAX. MIN. TYP. MAX.
VLMS1300-GS08 Super red 18 54 - 20 - 631 - 20 - 2.0 2.4 20 AlInGaP VLMO1300-GS08 Soft orange 45 90 - 20 - 605 - 20 - 2.0 2.4 20 AlInGaP VLMY1300-GS08 Yellow 28 - 180 20 584.5 - 597 20 1.8 - 2.4 20 AlInGaP VLMY1301-GS08 Yellow 71 - 180 20 584.5 - 597 20 1.8 - 2.4 20 AlInGaP VLMG1300-GS08 Yellow green 18 35 - 20 - 571 - 20 - 2.0 2.4 20 AlInGaP VLMTG1300-GS08 True green 71 - 450 20 - 525 - 20 2.8 3.2 3.6 20 InGaN VLMB1300-GS08 Blue 28 - 180 20 465 - 475 20 2.8 - 3.8 20 InGaN VLMB1302-GS08 Blue 45 - 112 20 465 - 475 20 2.8 - 3.8 20 InGaN VLMB1310-GS08 Blue 28 - 180 20 465 - 475 20 2.8 - 3.8 20 InGaN Rev. 1.6, 30-Mar-2023
1
Document Number: 82437 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
