Datasheet MAX6325, MAX6341, MAX6350 (Analog Devices) - 3
Description1ppm/°C, Low-Noise, +2.5V/+4.096V/+5V Voltage References
Pages / Page11 / 3 — 1ppm/°C, Low-Noise, +2.5V/+4.096V/+5V. Voltage References. ELECTRICAL …
File Format / SizePDF / 556 Kb
1ppm/°C, Low-Noise, +2.5V/+4.096V/+5V. Voltage References. ELECTRICAL CHARACTERISTICS—MAX6341. PARAMETER. SYMBOL. CONDITIONS. MIN
1ppm/°C, Low-Noise, +2.5V/+4.096V/+5V Voltage References ELECTRICAL CHARACTERISTICS—MAX6341 PARAMETER SYMBOL CONDITIONS MIN
MAX6325/MAX6341/MAX6350 MAX6325/MAX6341/MAX6350
(VIN = +10V, IOUT = 0mA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS TA MIN TYP MAX UNITS
Input Voltage Range VIN C, E, M 8 36 V Output Voltage VOUT MAX6341 +25°C 4.095 4.096 4.097 V MAX6341C_A C 0.5 1.0 Output Voltage Temperature TCV MAX6341E_A Coefficient (Note 1) OUT E 0.75 1.5 ppm/°C MAX6341MJA M 1.0 2.5 +25°C 10 18 C 30 8V ≤ VIN ≤ 10V E 35 ∆V M 45 Line Regulation (Note 2) OUT/ ∆ ppm/V VIN +25°C 2 5 C 7 10V ≤ VIN ≤ 36V E 8 M 10 C 1 6 Sourcing: 0mA ≤ IOUT ≤ 15mA E 1 7 M 3 9 ∆VOUT/ Load Regulation (Note 2) ∆ ppm/mA IOUT C 1 6 Sinking: -15mA ≤ IOUT ≤ 0mA E 1 7 M 7 18 +25°C 1.9 2.9 Supply Current IIN mA C, E, M 3.2 Trim-Adjustment Range ∆VOUT (Figure 1) C, E, M ±24 ±40 mV Turn-On Settling Time tON To ±0.01% of final value +25°C 8 µs 0.1Hz ≤ f ≤ 10Hz +25°C 2.4 µVp-p Output Noise Voltage (Note 3) en 10Hz ≤ f ≤ 1kHz +25°C 2.0 4.0 µVRMS Temperature Hysteresis (Note 4) +25°C 20 ppm ppm/ Long-Term Stability ∆VOUT/t +25°C 30 1000hr Maxim Integrated 3
