Datasheet SGL13, SGL41 (Vishay)
ManufacturerVishay
DescriptionSurface Mount Schottky Barrier Rectifier
Pages / Page5 / 1 — FEATURES. TYPICAL APPLICATIONS. LINKS TO ADDITIONAL RESOURCES. D 3. 3 D. …
File Format / SizePDF / 86 Kb
FEATURES. TYPICAL APPLICATIONS. LINKS TO ADDITIONAL RESOURCES. D 3. 3 D. 3D Models. MECHANICAL DATA. PRIMARY CHARACTERISTICS
Datasheet SGL13, SGL41 Vishay
BYM13-xx, SGL41-xx www.vishay.com Vishay General Semiconductor Surface Mount Schottky Barrier Rectifier
FEATURES
• MELF Schottky rectifier • Ideal for automated placement • Guardring for overvoltage protection • Low power losses, high efficiency • Low forward voltage drop • High surge capability • Meets MSL level 1, per J-STD-020, LF maximum peak of 250 °C GL41 (DO-213AB) • AEC-Q101 qualified • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
TYPICAL APPLICATIONS LINKS TO ADDITIONAL RESOURCES
For use in low voltage high frequency inverters, freewheeling, DC/DC converters, and polarity protection
D 3 3 D
applications
3D Models MECHANICAL DATA
Case: GL41 (DO-213AB)
Molding compound meets UL 94 V-0 flammability rating IF(AV) 1.0 A Base P/N-E3 - RoHS-compliant, commercial grade VRRM 20 V,30 V, 40 V, 50 V, 60 V Base P/NHE3 - RoHS-compliant, AEC-Q101 qualified IFSM 30 A Terminals: matte tin plated leads, solderable per VF 0.50 V, 0.70 V J-STD-002 and JESD 22-B102 TJ max. 125 °C, 150 °C E3 suffix meets JESD 201 class 1A whisker test, HE3 suffix Package GL41 (DO-213AB) meets JESD 201 class 2 whisker test Circuit configuration Single Polarity: two bands indicate cathode end 1st band denotes device type 2nd band denotes voltage type
MAXIMUM RATINGS
(TA = 25 °C unless otherwise noted) PARAMETER SYMBOL BYM13-20 BYM13-30 BYM13-40 BYM13-50 BYM13-60 UNIT DENOTES SCHOTTKY DEVICES: SGL41-20 SGL41-30 SGL41-40 SGL41-50 SGL41-60 1st BAND IS ORANGE Polarity color bands (2nd band) voltage type Gray Red Orange Yellow Green Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 V Maximum RMS voltage VRMS 14 21 28 35 42 V Maximum DC blocking voltage VDC 20 30 40 50 60 V Maximum average forward rectified current (fig. 1) IF(AV) 1.0 A Peak forward surge current 8.3 ms single half I sine-wave superimposed on rated load FSM 30 A Voltage rate of change (rated VR) dV/dt 10 000 V/μs Operating junction temperature range TJ -55 to +125 -55 to +150 °C Storage temperature range TSTG -55 to +150 °C Reivision: 01-Sep-2021 1 Document Number: 88548 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
