Datasheet TLVH431 (STMicroelectronics)
DescriptionAdjustable Shunt Voltage Reference
Pages / Page15 / 1 — TLVH431. Datasheet. production data. SOT23-3L. SOT23-5L. Description. …
File Format / SizePDF / 727 Kb
TLVH431. Datasheet. production data. SOT23-3L. SOT23-5L. Description. SOT323-6L. Features. Applications. Table 1. Device summary
Datasheet TLVH431 STMicroelectronics
TLVH431
Adjustable shunt voltage reference
Datasheet
production data
• Battery chargers • Switch mode power supplies • Battery operated equipment • Data acquisition systems • Energy management
SOT23-3L SOT23-5L Description SOT323-6L
The TLVH431 is a low power adjustable shunt voltage reference, with guaranteed temperature stability over the entire operating temperature
Features
range. • Adjustable output voltage: 1.24 V to 18 V The output voltage may be set to any value • Low operating current: 100 µA at 25 °C between 1.24 V and 18 V by means of an external • resistor divider. 0.25%, 0.5%, 1% and 1.5% voltage precision • The TLVH431 operates with a wide current range Sink current capability up to 60 mA from 100 µA to 60 mA with a typical dynamic • -40 to +125 °C temperature range impedance of 0.22 Ω. • 100 ppm/°C maximum temperature coefficient Available in SOT23-3L, SOT23-5L and SOT323- • Available in SOT23-3L, SOT23-5L and 6L surface mounted packages, it can be designed SOT323-6L packages in applications where space saving is a critical issue.
Applications
The low operating current is a key advantage for • power restricted designs. Computers
Table 1. Device summary Part number Precision Marking Package Temperature range
TLVH431AIL3T 0.5% H43A TLVH431BIL3T 0.25% H43B SOT23-3L TLVH431MIL3T 1% 43L TLVH431LIL3T 1.5% 43L TLVH431AIL5T 0.5% H43A -40 to +125°C TLVH431BIL5T 0.25% H43B SOT23-5L TLVH431LIL5T 1.5% 43L TLVH431AICT 0.5% H43 TLVH431BICT 0.25% H43 SOT323-6L TLVH431LICT 1.5% 43L September 2020 DocID023303 Rev 8 1/15 This is information on a product in full production. www.st.com Document Outline Table 1. Device summary 1 Pin configuration Figure 1. Pin configuration (top view) 2 Maximum ratings Table 2. Absolute maximum ratings Table 3. Thermal data Table 4. Operating conditions 3 Electrical characteristics Table 5. Electrical characteristics for TLVH431 4 Typical performance characteristics Figure 2. Test circuit for VKA = Vref Figure 3. Test circuit for VKA > Vref Figure 4. Reference voltage vs. temperature Figure 5. Minimum cathode current for regulation vs. temperature Figure 6. Off-state cathode current vs. temperature Figure 7. Reference input current vs. temperature Figure 8. Cathode current vs. cathode voltage Figure 9. DVref vs. DVKA Figure 10. Wideband noise Figure 11. Gain and phase vs. frequency Figure 12. Turn-on (no CLOAD) Figure 13. Turn-on (CLOAD = 10 nF) 5 Package information 5.1 SOT23-3L package information Figure 14. SOT23-3L package outline Table 6. SOT23-3L mechanical data 5.2 SOT23-5L package information Figure 15. SOT23-5L package outline Table 7. SOT23-5L mechanical data Figure 16. SOT23-5L recommended footprint (dimensions are in mm) 5.3 SOT323-6L package information Figure 17. SOT323-6L package outline Table 8. SOT323-6L mechanical data Figure 18. SOT323-6L recommended footprint (dimensions are in mm) 6 Revision History Table 9. Document revision history
