Datasheet TLVH431 (STMicroelectronics) - 5
DescriptionAdjustable Shunt Voltage Reference
Pages / Page15 / 5 — TLVH431. Electrical characteristics. Table 5. Electrical characteristics …
File Format / SizePDF / 727 Kb
TLVH431. Electrical characteristics. Table 5. Electrical characteristics for TLVH431. Symbol. Parameter. Test conditions. Min. Typ. Max
TLVH431 Electrical characteristics Table 5 Electrical characteristics for TLVH431 Symbol Parameter Test conditions Min Typ Max
TLVH431 Electrical characteristics 3 Electrical characteristics
Ik = 10 mA, Tamb = 25 °C (unless otherwise specified).
Table 5. Electrical characteristics for TLVH431 Symbol Parameter Test conditions Min. Typ. Max. Unit
VKA = Vref TLVH431A 0.5% 1.234 1.246 Vref Reference voltage TLVH431B 0.25% 1.237 1.24 1.243 V TLVH431M 1% 1.227 1.253 TLVH431L 1.5% 1.222 1.258 - 40 °C < Tamb < +125 °C Reference voltage TLVH431A 0.5% -26.7 +26.7 ∆Vref variation over TLVH431B 0.25% -23.5 +23.5 mV temperature range (1) TLVH431M 1% -32.8 +32.8 TLVH431L 1.5% -39 +39 ∆ Average temperature VKA/∆T V coefficient KA = Vref, - 40 °C < Tamb < +125 °C ±30 ±100 ppm/°C Minimum cathode VKA = Vref 60 100 Ikmin µA current for regulation VKA = VKAmax 160 200 Minimum cathode VKA = Vref, - 40 °C < Tamb < +125 °C 70 100 ∆Ikmin current variation over µA temperature range VKA = VKAmax, - 40 °C < Tamb < +125°C 100 200 Iref Reference input current R1 = 10 kΩ, R2 = ∞ 1.5 2.5 µA Reference current ∆ R I 1 = 10 kΩ, R2 = ∞ ref variation over 2.5 3.5 µA - 40 °C < T temperature range amb < + 125 °C Ratio of change in ∆VKA = 18 V to Vref -2 ∆Vref reference input voltage ------------ mV/V ∆Vka to change in cathode to ∆VKA = 18 V to Vref, - 40 °C < Tamb < +125 °C -2.5 anode voltage Ioff Off-state cathode current VKA = VKAmax,Vref = GND 10 80 nA ∆ Off-state cathode current V I KA = VKAmax,Vref = GND off 1000 2000 nA over temperature range - 40 °C < Tamb < +125 °C R  ∆ KA Static impedance VKA = Vref, IK = 100 µA to 60 mA 0.14 0.62 W Z  ∆ KA Dynamic impedance (2) VKA = Vref, IK = 10 mA to 60 mA, f ≤ 1 kHz 0.22 0.85 W en Wide band noise IK = 10 mA; 10 Hz < f < 100 kHz 30 mVRMS T ∆ ON Turn-on setting time VKA = Vref, IK = 10 mA 40 70 µsec 1. The tolerance values, across the temperature range, are calculated as: ±Vk25°C x {tolerance25°C+[(ppmmax /°C) x (∆T)]}. Example: TLVH431A ∆Vk = ±1.24 x (0.5% + 100 ppm/°C x 165 °C) = ±1.24 x (0.5%+1.65%)= ±1.24 x 2.15% = ± 26.7 mV. 2. The dynamic impedance is defined as Z =∆ KA VKA/∆Ik. Note: Limits are 100% production tested at 25 °C. Limits over the temperature range are guaranteed through correlation and by design. DocID023303 Rev 8 5/15 15 Document Outline Table 1. Device summary 1 Pin configuration Figure 1. Pin configuration (top view) 2 Maximum ratings Table 2. Absolute maximum ratings Table 3. Thermal data Table 4. Operating conditions 3 Electrical characteristics Table 5. Electrical characteristics for TLVH431 4 Typical performance characteristics Figure 2. Test circuit for VKA = Vref Figure 3. Test circuit for VKA > Vref Figure 4. Reference voltage vs. temperature Figure 5. Minimum cathode current for regulation vs. temperature Figure 6. Off-state cathode current vs. temperature Figure 7. Reference input current vs. temperature Figure 8. Cathode current vs. cathode voltage Figure 9. DVref vs. DVKA Figure 10. Wideband noise Figure 11. Gain and phase vs. frequency Figure 12. Turn-on (no CLOAD) Figure 13. Turn-on (CLOAD = 10 nF) 5 Package information 5.1 SOT23-3L package information Figure 14. SOT23-3L package outline Table 6. SOT23-3L mechanical data 5.2 SOT23-5L package information Figure 15. SOT23-5L package outline Table 7. SOT23-5L mechanical data Figure 16. SOT23-5L recommended footprint (dimensions are in mm) 5.3 SOT323-6L package information Figure 17. SOT323-6L package outline Table 8. SOT323-6L mechanical data Figure 18. SOT323-6L recommended footprint (dimensions are in mm) 6 Revision History Table 9. Document revision history
