Datasheet TL432LI-Q1 (Texas Instruments) - 10
Description | Automotive, adjustable, precision shunt regulator with optimized reference current |
Pages / Page | 35 / 10 — TL431LI-Q1. TL432LI-Q1. www.ti.com. 8.2 Dynamic Impedance. Figure 17. … |
TL431LI-Q1. TL432LI-Q1. www.ti.com. 8.2 Dynamic Impedance. Figure 17. Dynamic Impedance
link to page 9 link to page 4 link to page 10
TL431LI-Q1 TL432LI-Q1
SNVSBA4A – MAY 2019 – REVISED NOVEMBER 2019
www.ti.com 8.2 Dynamic Impedance
' K V A K Z A The dynamic impedance is defined as ' K I A . When the device is operating with two external resistors 'V z' (see Figure 15), the total dynamic impedance of the circuit is given by 'I , which is approximately equal to § R1 · K Z A ¨1 ¸ © R2 ¹ . The VKA of the TL431LI-Q1 can be affected by the dynamic impedance. The TL431LI-Q1 test current Itest for VKA is specified in the Electrical Characteristics. Any deviation from Itest can cause deviation on the output VKA. Figure 17 shows the effect of the dynamic impedance on the VKA. ) A (m A I I K test / P IKA IKA(min) 0 VKA (V) Ps
10 Submit Documentation Feedback Copyright © 2019, Texas Instruments Incorporated Product Folder Links: TL431LI-Q1 TL432LI-Q1 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Table 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Electrical Characteristics 7.6 Typical Characteristics 8 Parameter Measurement Information 8.1 Temperature Coefficient 8.2 Dynamic Impedance 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.4 Device Functional Modes 9.4.1 Open Loop (Comparator) 9.4.2 Closed Loop 10 Applications and Implementation 10.1 Application Information 10.2 Typical Applications 10.2.1 Comparator With Integrated Reference 10.2.2 Design Requirements 10.2.3 Detailed Design Procedure 10.2.3.1 Basic Operation 10.2.3.2 Output Voltage and Logic Input Level 10.2.4 Application Curves 10.2.5 Precision LED Lighting Current Sink Regulator 10.2.5.1 Design Requirements 10.2.5.2 Detailed Design Procedure 10.2.6 Shunt Regulator/Reference 10.2.6.1 Design Requirements 10.2.6.2 Detailed Design Procedure 10.2.6.3 Application Curves 10.2.7 Isolated Flyback with Optocoupler 10.2.7.1 Design Requirements 10.2.7.2 Detailed Design Procedure 10.3 System Examples 11 Power Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Device Support 13.1.1 Device Nomenclature 13.2 Documentation Support 13.2.1 Related Documentation 13.3 Related Links 13.4 Receiving Notification of Documentation Updates 13.5 Support Resources 13.6 Trademarks 13.7 Electrostatic Discharge Caution 13.8 Glossary 14 Mechanical, Packaging, and Orderable Information
