Datasheet TS4061 (STMicroelectronics) - 5
DescriptionPrecision Micropower Shunt Voltage Reference
Pages / Page15 / 5 — TS4061. Electrical characteristics. 3 Electrical. characteristics. Table …
File Format / SizePDF / 661 Kb
TS4061. Electrical characteristics. 3 Electrical. characteristics. Table 4. Electrical characteristics for TS4061. Symbol
TS4061 Electrical characteristics 3 Electrical characteristics Table 4 Electrical characteristics for TS4061 Symbol
Limits are 100% production tested at 25 °C. Limits over full temperature range are guaranteed through correlation and by design. Ik = 10 µA, Tamb = 25 °C (unless otherwise specified).
Table 4. Electrical characteristics for TS4061 Symbol Parameter Test conditions Min. Typ. Max. Unit
Ik = 10 A, 1.2237 1.2262 Reverse breakdown TS4061A 1.225 V voltage (Vk = 1.225 V) Ik = 10 A, 1.2225 1.2275 TS4061B Vk Ik = 10 A, 1.2487 1.2512 Reverse breakdown TS4061A 1.25 V voltage (Vk = 1.25 V) Ik = 10 A, 1.2475 1.2525 TS4061B Minimum operating Tamb = 25 °C 7.5 10 A Ikmin current -40 °C < Tamb < +85 °C 12 Average temperature  ppm/° Vk/T 10 A < I coefficient k < 15 mA 20 35 C Reverse breakdown Ikmin < Ik < 1 mA 0.2 1 voltage change with -40 °C < T  amb < +85 °C Vk/Ik mV operating current 1mA < Ik < 15 mA range 1.7 4 -40 °C < Tamb < +85 °C Rka Static impedance Ik = 10 A to 10 mA 0.15 0.3 Ω Hys Thermal hysteresis(1) Ik = 10 A 120 ppm Wideband noise Ik = 10 A 10 Hz < f< 10 kHz 95 VRMS Noise Low frequency noise Ik = 10 A 0.1 Hz < f< 10 Hz 10 µVp-p 1. Thermal hysteresis is defined as the difference in voltage measured at +25 °C after cycling to -40 °C and the measurement at +25 °C after cycling to temperature +85 °C. DocID026252 Rev 2 5/15 15 Document Outline 1 Pin configuration Figure 1. Pin configuration SOT23-3L, SOT323-3L (top view) 2 Maximum ratings Table 1. Absolute maximum ratings Table 2. Thermal data Table 3. Operating conditions 3 Electrical characteristics Table 4. Electrical characteristics for TS4061 4 Typical performance characteristics Figure 2. VK change vs temperature (1.225 V version) Figure 3. VK change vs temperature (1.25 V version) Figure 4. IKmin minimum current for regulation Figure 5. IKmin minimum current for regulation vs temperature Figure 6. Output impedance vs frequency Figure 7. Forward characteristics Figure 8. Start-up waveform (no Cload) Figure 9. Start-up waveform (Cload = 100 nF) Figure 10. Low frequency noise 5 Package mechanical data 5.1 SOT23-3L, TS4061 Figure 11. SOT23-3L mechanical drawings Table 5. SOT23-3L mechanical data Figure 12. SOT23-3L recommended footprint 5.2 SOT323-3L, TS4061 Figure 13. SOT323-3L drawings Table 6. SOT323-3L mechanical data Figure 14. SOT323-3L recommended footprint 6 Ordering information Table 7. Order codes 7 Revision history Table 8. Document revision history
