Datasheet TS4061 (STMicroelectronics) - 6
Manufacturer | STMicroelectronics |
Description | Precision Micropower Shunt Voltage Reference |
Pages / Page | 15 / 6 — Typical performance characteristics. TS4061. Figure 2. VK change vs … |
File Format / Size | PDF / 661 Kb |
Typical performance characteristics. TS4061. Figure 2. VK change vs temperature. Figure 3. VK change vs temperature
Typical performance characteristics TS4061 4 Typical performance characteristics
(The following plots are referred to the typical application circuit and, unless otherwise noted, at TA = 25 °C)
Figure 2. VK change vs temperature Figure 3. VK change vs temperature (1.225 V version) (1.25 V version) ,N $ ,N $ ,N P$ ,N P$ P 9
9 $
7>&@
. 9,.
7>&@
*,3*59 *,3*59
Figure 4. IKmin minimum current for regulation Figure 5. IKmin minimum current for regulation vs temperature 9N 9 9N 9 $ LQ , .P 9N 9
7D & *,3*59
7>&@
*,3*59
Figure 6. Output impedance vs frequency Figure 7. Forward characteristics P K R H SHGDQF ,P 1R&ORDG ± ,N X$ &R Q)± ,N X$ &R Q)± ,N X$ 1R&ORDG ± ,N P$ &R Q)± ,N P$ &R Q)± ,N P$ , IUHTXHQF\.+] .IRUZDUG>P$@
*,3*59 *,3*59 6/15 DocID026252 Rev 2 Document Outline 1 Pin configuration Figure 1. Pin configuration SOT23-3L, SOT323-3L (top view) 2 Maximum ratings Table 1. Absolute maximum ratings Table 2. Thermal data Table 3. Operating conditions 3 Electrical characteristics Table 4. Electrical characteristics for TS4061 4 Typical performance characteristics Figure 2. VK change vs temperature (1.225 V version) Figure 3. VK change vs temperature (1.25 V version) Figure 4. IKmin minimum current for regulation Figure 5. IKmin minimum current for regulation vs temperature Figure 6. Output impedance vs frequency Figure 7. Forward characteristics Figure 8. Start-up waveform (no Cload) Figure 9. Start-up waveform (Cload = 100 nF) Figure 10. Low frequency noise 5 Package mechanical data 5.1 SOT23-3L, TS4061 Figure 11. SOT23-3L mechanical drawings Table 5. SOT23-3L mechanical data Figure 12. SOT23-3L recommended footprint 5.2 SOT323-3L, TS4061 Figure 13. SOT323-3L drawings Table 6. SOT323-3L mechanical data Figure 14. SOT323-3L recommended footprint 6 Ordering information Table 7. Order codes 7 Revision history Table 8. Document revision history
