Datasheet TSM1012 (STMicroelectronics)
DescriptionLow Consumption Voltage and Current Controller for Battery Chargers and Adaptors
Pages / Page14 / 1 — TSM1012. Datasheet. production data. Description. Features. Figure 1. Pin …
File Format / SizePDF / 284 Kb
TSM1012. Datasheet. production data. Description. Features. Figure 1. Pin connections (top view). Voltage reference. Applications
Datasheet TSM1012 STMicroelectronics
TSM1012
Low consumption voltage and current controller for battery chargers and adapters
Datasheet
production data Description
The TSM1012 is a highly integrated solution for SMPS applications requiring the CV (constant voltage) and CC (constant current) mode. % 40 TheTSM1012 device integrates one voltage QMBTUJD QBDLBHF reference and two operational amplifiers (with ORed outputs - common collectors).
Features
The voltage reference combined with one operational amplifier makes it an ideal voltage Constant voltage and constant current control controller. The other operational amplifier, Low consumption combined with few external resistors and the Low voltage operation voltage reference, can be used as a current limiter. Low external component count Current sink output stage
Easy compensation High ac mains voltage rejection 7SFG 7$$
Voltage reference
7 7 – Fixed output voltage reference 1.25 V $$ 0VU – 0.5% and 1% voltage precision $$ $$ (/%
Applications
$7 $7 7 Adapters Battery chargers ".
Table 1. Order codes Package Part number Temperature range D(1) Vref (%) Marking
TSM1012I -40 to 105 °C • 1 M1012 TSM1012AI -40 to 105 °C • 0.5 M1012A 1.
D =
“Small Outline” package (SO) - also available in tape and reel (DT). April 2016 DocID10124 Rev 2 1/14 This is information on a product in full production. www.st.com Document Outline Figure 1. Pin connections (top view) Table 1. Order codes 1 Pin descriptions Table 2. SO-8 pinout 2 Absolute maximum ratings Table 3. Absolute maximum ratings 3 Operating conditions Table 4. Operating conditions 4 Electrical characteristics Table 5. Electrical characteristics 5 Internal schematics Figure 2. Internal schematic Figure 3. Typical adapter or battery charger application using TSM1012 6 Principle of operation and application hints 6.1 Voltage and current control 6.1.1 Voltage control 6.1.2 Current control Figure 4. Output voltage versus output current 6.2 Compensation 6.3 Start-up and short-circuit conditions 6.4 Voltage clamp Figure 5. Clamp voltage Figure 6. Typical application schematic 7 Package information 7.1 SO-8 package information Figure 7. SO-8 package outline Table 6. SO-8 package mechanical data 8 Revision history Table 7. Document revision history
