Datasheet MAX6069 (Analog Devices) - 3
Description1μA WLP Precision Shunt Voltage Reference
Pages / Page9 / 3 — MAX6069. Electrical Characteristics (continued). PARAMETER. SYMBOL. …
File Format / SizePDF / 645 Kb
MAX6069. Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. MAX6069B (2.048V). MAX6069C (2.500V)
MAX6069 Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS MAX6069B (2.048V) MAX6069C (2.500V)
MAX6069
1μA Ultra-Tiny Shunt Voltage Reference
(TA=-40°C to +125°C, unless otherwise noted., Typical values are at TA = +25°C. (Note 1))
IR = 1.2µA, TA = -40°C to +85°C 20 Temperature Coefficient MAX6069AA TA = -40°C to +125°C 25 (Note 3) TC ppm/°C IR = 1.2µA, TA = -40°C to +85°C 50 MAX6069AB TA = -40°C to +125°C 75 Long-Term Drift 1000h at TA = +25°C 150 ppm Thermal Hysteresis (Note 4) 200 ppm
MAX6069B (2.048V)
MAX6069BA (0.2%) 2.0439 2.048 2.0521 Reverse Breakdown Voltage V TA = +25°C, R I V R = 1.2µA MAX6069BB (0.5%) 2.0378 2.048 2.0582 Minimum Operating Current IRMIN VR change < 0.2% from VR at IR = 1.2μA 0.5 1.0 µA Reverse Breakdown Change IR = 1.2μA to 200μA 1.3 with Current mV IR = 200μA to 2mA 2.3 Reverse Dynamic Impedance IR = 1.2μA to 2mA (Note 2) 1.8 Ω Low-Frequency Noise IR = 1.2μA, f = 0.1Hz to 10Hz 50 µVp-p Temperature Coefficient (Note 3) T I A = -40°C to +85°C 20 ppm/°C R = 1.2µA, Temperature Coefficient MAX6069BA (Note 3) TA = -40°C to +125°C 25 ppm/°C TC Temperature Coefficient (Note 3) T I A = -40°C to +85°C 50 ppm/°C R = 1.2µA, Temperature Coefficient MAX6069BB (Note 3) TA = -40°C to +125°C 75 ppm/°C Long-Term Drift 1000h at TA = +25°C 150 ppm Thermal Hysteresis (Note 4) 200 ppm
MAX6069C (2.500V)
MAX6069CA (0.2%) 2.4950 2.5000 2.5050 Reverse Breakdown Voltage V TA = +25°C, R I V R = 1.2µA MAX6069CB (0.5%) 2.4875 2.5000 2.5125 Minimum Operating Current IRMIN VR change < 0.2% from VR at IR = 1.2μA 0.5 1.0 µA Reverse Breakdown Change IR = 1.2μA to 200μA 1.5 with Current mV IR = 200μA to 2mA 2.5 Reverse Dynamic Impedance IR = 1.2μA to 2mA (Note 2) 2 Ω www.analog.com Analog Devices │ 3
