Datasheet MAX6069 (Analog Devices)
Description | 1μA WLP Precision Shunt Voltage Reference |
Pages / Page | 9 / 1 — Evaluation Kit. Design. Tools. Support. Available. Resources. and Models. … |
File Format / Size | PDF / 645 Kb |
Evaluation Kit. Design. Tools. Support. Available. Resources. and Models. 1μA Ultra-Tiny Shunt Voltage Reference. MAX6069
link to page 8
Evaluation Kit Design Tools Support Available Resources and Models
Click here to ask an associate for production status of specific part numbers.
1μA Ultra-Tiny Shunt Voltage Reference MAX6069 General Description Benefits and Features
The MAX6069 ultra-low-power shunt references are ideal ● Wide Operating Current Range: 1μA to 2mA for space-critical and low-power applications. They are ● 0.88mm x 1.16mm, 4-Bump WLP offered in a 4-bump wafer-level package (WLP), and the minimum operating current is guaranteed to be less ● Initial Voltage Accuracy: 0.2% than 1μA. These references feature low temperature ● Temperature Coefficient: 20ppm/°C (max) coefficients of less than 20ppm/°C and initial accuracy of ● Temperature Range: -40°C to +125°C better than 0.2%. ● Factory-Trimmed Output Voltages: +1.25V, +2.048V, Available with +1.25V, +2.048V, +2.5V, and 3V output +2.5V, +3.0V voltages, these references can be used as lower- power, higher-precision upgrades to the ICL8069, LM385, ● Functionally Equivalent to the MAX6006/MAX6007/ LT1004, and LM4040 in much smaller packages. Two MAX6008/MAX6009 grades are available: A and B. The A grade features a temperature coefficient of 25ppm/°C over the extended
Ordering Information appears at end of data sheet.
temperature range of -40°C to +85°C, with an initial accuracy of 0.2%. Grade B features a temperature coefficient of 50ppm/°C over the extended temperature range of -40°C to +85°C, with an initial accuracy of 0.5%.
Simplified Block Diagram
Their tiny wafer-level packages make these references ideal for equipment with very small form factors. OUT
Applications
● Portable Sensors
MAX6069
● Portable Meters ● Precision Regulators ● A/D and D/A Converters GND ● 4mA–20mA Loop-Powered Sensors 19-100064; Rev 1; 10/21 © 2021 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. One Analog Way, Wilmington, MA 01887 U.S.A. | Tel: 781.329.4700 | © 2021 Analog Devices, Inc. All rights reserved.
