Datasheet MAX6520 (Analog Devices) - 3
Description | 50ppm/°C, SOT23, 3-Terminal, 1.2V Voltage Reference |
Pages / Page | 6 / 3 — 50ppm/°C, SOT23, 3-Terminal,. 1.2V Voltage Reference. MAX6520 |
File Format / Size | PDF / 331 Kb |
50ppm/°C, SOT23, 3-Terminal, 1.2V Voltage Reference MAX6520 ____________________________Typical Operating Characteristics (continued)
(VIN = 3V, ILOAD = 0mA, TA = +25°C, unless otherwise noted.)
LOAD REGULATION OUTPUT VOLTAGE POWER-SUPPLY REJECTION RATIO vs. TEMPERATURE vs. SOURCE CURRENT vs. FREQUENCY
0.32 1.2001 120 MAX6520 TOC-03 MAX6520 TOC-06 MAX6520 TOC-05 µA) 0.24 1.2000 100 µV/ 0.16 1.1999 80 PSRR (dB) OUTPUT VOLTAGE (V) 0.08 1.1998 60 LOAD REGULATION ( 0 1.1997 40 -50 -25 0 25 50 75 100 1 10 100 1000 0.0001 0.001 0.01 0.1 .01 .10 TEMPERATURE (°C) SOURCE CURRENT ( FREQUENCY (kHz) µA)
0.1Hz TO 100Hz NOISE LOAD-TRANSIENT RESPONSE
A 50µV/div B 10µs/div 1µs/div A = OUTPUT CURRENT, 50µA/div, ILOAD = 0µA TO -50µA B = OUTPUT VOLTAGE, 100mV/div
LOAD-TRANSIENT RESPONSE LINE-TRANSIENT RESPONSE
A IN A B OUT B 10µs/div 5µs/div A = OUTPUT CURRENT, 500µA/div, ILOAD = 0µA TO 500µA A = INPUT VOLTAGE, 100mV/div, VIN = 3V ± 50mV B = OUTPUT VOLTAGE, 100mV/div B = OUTPUT VOLTAGE, 10mV/div
_______________________________________________________________________________________ 3
