VOFD343A www.vishay.com Vishay Semiconductors 4 A Output Current IGBT and MOSFET DriverDESCRIPTION The VOFD343A consists of a AlGaAs LED optically coupled to an integrated circuit with a power output stage. This optocoupler is ideally suited for driving power IGBTs and MOSFETs used in motor control inverter applications. The high operating voltage range of the output stage provides the drive voltages required by gate controlled devices. The VOFD343A is ideally suited for directly driving IGBTs with ratings up to 1200 V / 100 A. For IGBTs with higher ratings, the VOFD343A can be used to drive a discrete power stage which drives the IGBT gate. FEATURES • 3.0 A minimum peak current • 4.0 A peak maximum output current • Rail-to-rail output stage • Maximum propagation delay 200 ns • Maximum propagation delay difference 100 ns • 35 kV/μs common mode rejection ratio • Wide operating range of 15 V to 30 V • Extended temperature range of -40 °C to +125 °C • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912 A 1 6 VCC APPLICATIONS • Isolated IGBT / MOSFET gate driver 2 5 VO • AC and brushless DC motor drives • Induction stove top C 3 4 VEE Shield • Industrial inverters • Uninterruptible power supplies (UPS) V D E AGENCY APPROVALS • UL1577 • cUL • DIN EN 60747-5-5 (VDE 0884-5), available with option 1 LINKS TO ADDITIONAL RESOURCESDesign ToolsRelatedEDA / CADModelsEvaluationDocumentsBoards Rev. 1.0, 20-Jun-2024 1 Document Number: 80486 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
