Datasheet BRT21, BRT22, BRT23 (Vishay) - 4
ManufacturerVishay
DescriptionOptocoupler, Phototriac Output, Zero Crossing
Pages / Page9 / 4 — BRT21, BRT22, BRT23. SAFETY AND INSULATION RATINGS PARAMETER. TEST …
File Format / SizePDF / 203 Kb
BRT21, BRT22, BRT23. SAFETY AND INSULATION RATINGS PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT. Note. POWER FACTOR CONSIDERATIONS
BRT21, BRT22, BRT23 SAFETY AND INSULATION RATINGS PARAMETER TEST CONDITION SYMBOL VALUE UNIT Note POWER FACTOR CONSIDERATIONS
BRT21, BRT22, BRT23
Climatic classification According to IEC 68 part 1 40 / 100 / 21 Pollution degree According to DIN VDE 0109 2 Comparative tracking index Insulation group IIIa CTI 175 Maximum rated withstanding isolation voltage According to UL1577, t = 1 min VISO 4420 VRMS Tested withstanding isolation voltage According to UL1577, t = 1 s VISO 5300 VRMS Maximum transient isolation voltage According to DIN EN 60747-5-5 VIOTM 6000 Vpeak Maximum repetitive peak isolation voltage According to DIN EN 60747-5-5 VIORM 630 Vpeak VIO = 500 V, Tamb = 25 °C RIO ≥ 1012 Ω Isolation resistance VIO = 500 V, Tamb = 100 °C RIO ≥ 1011 Ω Output safety power PSO 200 mW Input safety current ISI 400 mA Input safety temperature TS 175 °C Creepage distance DIP-6; SMD-6, option 7; ≥ 7 mm SMD-6 option 9 Clearance distance ≥ 7 mm Creepage distance ≥ 8 mm DIP-6, option 6; SMD-6, option 8 Clearance distance ≥ 8 mm Insulation thickness DTI ≥ 0.4 mm
Note
• As per IEC 60747-5-5, § 7.4.3.8.2, this optocoupler is suitable for “safe electrical insulation” only within the safety ratings. Compliance with the safety ratings shall be ensured by means of protective circuits.
A snubber is not needed to eliminate false operation of the TRIAC driver because of the high static and commutating 1 C dV/dt with loads between 1.0 and 0.8 power factors. When s (µF) = 0.0032 (µF) x 100.0066 IL (mA) inductive loads with power factors less than 0.8 are being driven, include a RC snubber or a single capacitor directly 0.1 across the device to damp the peak commutating dV/dt spike. Normally a commutating dV/dt causes a turning-off device to stay on due to the stored energy remaining in the turning-off device. 0.01 But in the case of a zero voltage crossing optotriac, the - Shunt Capacitance (µF) s T = 25 °C, PF = 0.3, commutating dV/dt spikes can inhibit one half of the TRIAC C amb I = 2.0 mA F from turning on. If the spike potential exceeds the inhibit 0.001 voltage of the zero cross detection circuit, half of the TRIAC 0 50 100 150 200 250 300 350 400 will be heldoff and not turn-on. This hold-off condition can iil410_01 IL - Load Current (mA ) RMS be eliminated by using a snubber or capacitor placed directly across the optotriac as shown in figure 1. Note that Fig. 1 - Shunt Capacitance vs. Load Current the value of the capacitor increases as a function of the load current. The hold-off condition also can be eliminated by providing a higher level of LED drive current. The higher LED drive provides a larger photocurrent which causes the phototransistor to turn-on before the commutating spike has activated the zero cross network. Figure 2 shows the relationship of the LED drive for power factors of less than 1.0. The curve shows that if a device requires 1.5 mA for a resistive load, then 1.8 times 2.7 mA) that amount would be required to control an inductive load whose power factor is less than 0.3. Rev. 2.1, 21-Jun-2023
4
Document Number: 83690 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
