Datasheet BRT21, BRT22, BRT23 (Vishay)
ManufacturerVishay
DescriptionOptocoupler, Phototriac Output, Zero Crossing
Pages / Page9 / 1 — BRT21, BRT22, BRT23. Optocoupler, Phototriac Output, Zero Crossing. …
File Format / SizePDF / 203 Kb
BRT21, BRT22, BRT23. Optocoupler, Phototriac Output, Zero Crossing. FEATURES. APPLICATIONS. LINKS TO ADDITIONAL RESOURCES
Datasheet BRT21, BRT22, BRT23 Vishay
BRT21, BRT22, BRT23
Optocoupler, Phototriac Output, Zero Crossing FEATURES
• Low trigger current IFT = 1.2 mA • ITRMS = 300 mA A 1 6 MT2 • High static dV/dt 10 000 V/μs • Load voltage = 800 V C 2 5 NC • Zero voltage crossing detector • Material categorization: NC 3 ZCC* 4 MT1 for definitions of compliance please see www.vishay.com/doc?99912 *Zero crossing circuit
• Industrial controls • Office equipment 23128 • Consumer appliances
LINKS TO ADDITIONAL RESOURCES AGENCY APPROVALS
• UL 1577
Related Models
• cUL 1577
Documents
• DIN EN 60747-5-5 (VDE 0884-5), available with option 1
DESCRIPTION
The BRT21, BRT22, BRT23 product family consists of an optically coupled GaAs IRLED to a photosensitive thyristor system with integrated noise suppression and zero crossing circuit. The thyristor system enables low trigger currents of 1.2 mA and features a dV/dt ratio of greater than 10 kV/μs and load voltages up to 800 V. The BRT21, BRT22, BRT23 product family is a perfect microcontroller friendly solution to isolate low voltage logic from high voltage 120 VAC, 240 VAC, and 380 VAC lines and to control resistive, inductive, or capacitive AC loads like motors, solenoids, high power thyristors, or TRIACs and solid-state relays.
ORDERING INFORMATION
DIP Option 6
B R T 2 # x - X 0 # # T
10.16 mm 7.62 mm PART NUMBER PACKAGE OPTION TAPE AND Option 7 Option 9 REEL > 0.7 mm > 0.1 mm
V AGENCY CERTIFIED / PACKAGE DRM (V)
400
600
800 UL, cUL IFT = 2 mA IFT = 1.2 mA IFT = 2 mA IFT = 1.2 mA IFT = 2 mA
DIP-6 BRT21H BRT22F BRT22H BRT23F BRT23H DIP-6, 400 mil, option 6 - - - BRT23F-X006 - SMD-6, option 7 - BRT22F-X007T BRT22H-X007T (1) BRT23F-X007T BRT23H-X007T (1) SMD-6, option 9 - BRT22F-X009T - BRT23F-X009T -
UL, cUL, VDE (Option 1) IFT = 2 mA IFT = 1.2 mA IFT = 2 mA IFT = 1.2 mA IFT = 2 mA
DIP-6 - BRT22F-X001 - - BRT23H-X001 DIP-6, option 6 - - BRT22H-X016 - BRT22H-X016
Note
(1) Also available in tube, do not put T on the end Rev. 2.1, 21-Jun-2023
1
Document Number: 83690 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
