Datasheet BRT21, BRT22, BRT23 (Vishay) - 2
ManufacturerVishay
DescriptionOptocoupler, Phototriac Output, Zero Crossing
Pages / Page9 / 2 — BRT21, BRT22, BRT23. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. …
File Format / SizePDF / 203 Kb
BRT21, BRT22, BRT23. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. PART. SYMBOL. VALUE. UNIT. INPUT. OUTPUT. COUPLER. Note
BRT21, BRT22, BRT23 ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION PART SYMBOL VALUE UNIT INPUT OUTPUT COUPLER Note
BRT21, BRT22, BRT23
(Tamb = 25 °C, unless otherwise specified)
Reverse voltage IR = 10 μA VR 6 V Forward current IF 60 mA Surge current IFSM 2.5 A Power dissipation Pdiss 100 mW Derate from 25 °C 1.33 mW/°C
OUTPUT
BRT21 VDRM 400 V Peak off-state voltage BRT22 VDRM 600 V BRT23 VDRM 800 V On state RMS current ITRM 300 mA Single cycle surge current 3 A Power dissipation Pdiss 600 mW Derate from 25 °C 6.6 mW/°C
COUPLER
Storage temperature range Tstg -40 to +150 °C Ambient temperature range Tamb -40 to +100 °C Max. ≤ 10 s dip soldering Soldering temperature ≥ T 0.5 mm from case bottom sld 260 °C
Note
• Stresses in excess of the absolute maximum ratings can cause permanent damage to the device. Functional operation of the device is not implied at these or any other conditions in excess of those given in the operational sections of this document. Exposure to absolute maximum ratings for extended periods of the time can adversely affect reliability. Rev. 2.1, 21-Jun-2023
2
Document Number: 83690 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
