Datasheet TEA1501 (NXP)
ManufacturerNXP
DescriptionGreenChip SMPS Controller IC
Pages / Page21 / 1 — TEA1501 GreenChip SMPS controller IC. Rev. 02 — 31 March 2006. Product …
File Format / SizePDF / 116 Kb
TEA1501 GreenChip SMPS controller IC. Rev. 02 — 31 March 2006. Product data sheet. General description. Features
Datasheet TEA1501 NXP
link to page 4
TEA1501 GreenChip SMPS controller IC Rev. 02 — 31 March 2006 Product data sheet 1. General description
The TEA1501 is the low power member of the GreenChip family and is especially designed for standby Switched Mode Power Supply (SMPS) applications. The TEA1501 incorporates all the necessary functions for an efficient and low cost power supply for 90 V to 276 V AC universal input. The TEA1501 is a monolithic integrated circuit and is available in a SO8 package. The design is made in the BCD_PowerLogic750 process and includes the high voltage switching device. Using only seven functional pins, the TEA1501 contains extensive control functions to form a flexible and a reliable power supply with a minimum of external components. The TEA1501 operates in a flyback topology (see Figure 3) with a fixed switching frequency, constant primary peak current control and regulates the output voltage in Burst mode. Applications include low power and standby power supplies as used in television, monitor, lighting electronics and domestic appliances with an output power from 0.1 W to 3 W.
2. Features 2.1 Distinctive features
n Direct off-line operation (90 V to 276 V AC) n Low external component count n Integrated high voltage start-up current source for a fast start-up within 0.25 s n Integrated power switch: 650 V, 40 Ω, 0.25 A n Programmable primary peak current n Data transfer from isolated secondary side to non-isolated primary side via the transformer n On/off function replaces expensive mains switch by a functional switch
2.2 Green features
n Low current consumption in Off mode, typical 40 µA n Efficient Burst mode operation, for 0.1 W to 3 W output power
2.3 Protection features
n Cycle-by-cycle current control with programmable primary peak current n Overvoltage protection n Undervoltage lockout n Overtemperature protection Document Outline 1. General description 2. Features 2.1 Distinctive features 2.2 Green features 2.3 Protection features 3. Quick reference data 4. Ordering information 5. Block diagram 6. Pinning information 6.1 Pinning 6.2 Pin description 7. Functional description 7.1 System operation 7.1.1 On/off 7.1.2 Start-up 7.1.3 Operation 7.1.4 Data transfer 7.2 Waveforms in the Off mode, Start-up mode and Operation mode 7.3 Circuit block description 7.3.1 On/off/data section 7.3.2 VAUX management 7.3.3 Start-up current source 7.3.4 Reference block 7.3.5 Temperature protection 7.3.6 Switch oscillator 7.3.7 Burst oscillator 7.3.8 Gate driver 7.3.9 Power switch 7.3.10 Primary current comparator 7.3.11 Leading edge blanking 7.3.12 Modulator 7.3.13 Counter 7.3.14 Supply current tracking 7.4 Design Equations 7.4.1 Primary peak current 7.4.1.1 Minimum value of RSOURCE 7.4.2 Switch oscillator 7.4.2.1 Range of RREF values 7.4.3 Leading edge blanking 7.4.4 Burst oscillator 7.4.4.1 Minimum value of CBURST 8. Limiting values 9. Thermal characteristics 10. Characteristics 11. Test information 11.1 Quality information 12. Package outline 13. Soldering 13.1 Introduction to soldering surface mount packages 13.2 Reflow soldering 13.3 Wave soldering 13.4 Manual soldering 13.5 Package related soldering information 14. Revision history 15. Legal information 15.1 Data sheet status 15.2 Definitions 15.3 Disclaimers 15.4 Trademarks 16. Contact information 17. Contents
