Datasheet SA571 (ON Semiconductor)
ManufacturerON Semiconductor
DescriptionCompandor
Pages / Page12 / 1 — http://onsemi.com. MARKING. DIAGRAMS. Features. SOIC−16 WB. D SUFFIX. …
File Format / SizePDF / 230 Kb
http://onsemi.com. MARKING. DIAGRAMS. Features. SOIC−16 WB. D SUFFIX. CASE 751G. Applications. PDIP−16. N SUFFIX. CASE 648. PIN CONNECTIONS
Datasheet SA571 ON Semiconductor
link to page 9 SA571 Compandor The SA571 is a versatile low cost dual gain control circuit in which either channel may be used as a dynamic range compressor or expandor. Each channel has a full−wave rectifier to detect the average value of the signal, a linerarized temperature−compensated variable gain cell, and an operational amplifier.
http://onsemi.com
The SA571 is well suited for use in cellular radio and radio communications systems, modems, telephone, and satellite broadcast/receive audio systems.
MARKING DIAGRAMS Features
• 16 Complete Compressor and Expandor in one IChip 16 • Temperature Compensated • 1 SA571D Greater than 110 dB Dynamic Range AWLYYWWG • Operates Down to 6.0 VDC
SOIC−16 WB
D SUFFIX
System Levels Adjustable with External Components
CASE 751G
• 1 Distortion may be Trimmed Out • Dynamic Noise Reduction Systems • Voltage Controlled Amplifier • 16 Pb−Free Packages are Available* 16 SA571N
Applications
1 AWLYYWWG • Cellular Radio
PDIP−16
1 •
N SUFFIX
High Level Limiter
CASE 648
• Low Level Expandor − Noise Gate • A = Assembly Location Dynamic Filters WL = Wafer Lot • CD Player YY = Year WW = Work Week G = Pb−Free Package
PIN CONNECTIONS D, and N Packages*
RECT CAP 1 1 16 RECT CAP 2 RECT IN 1 2 15 RECT IN 2 DG CELL IN 1 3 14 DG CELL IN 2 GND 4 13 VCC 5 12 INV. IN 1 INV. IN 2 RES. R 6 11 3 1 RES. R3 2 7 OUTPUT 1 10 OUTPUT 2 8 9 THD TRIM 1 THD TRIM 2 TOP VIEW *SOL − Released in Large SO Package Only.
ORDERING INFORMATION
*For additional information on our Pb−Free strategy and soldering details, please See detailed ordering and shipping information in the package download the ON Semiconductor Soldering and Mounting Techniques dimensions section on page 9 of this data sheet. Reference Manual, SOLDERRM/D. © Semiconductor Components Industries, LLC, 2006
1
Publication Order Number:
March, 2006 − Rev. 4 SA571/D
