Datasheet AWSCR-CPLB (Abracon)
ManufacturerAbracon
DescriptionSMD Ceramic Resonator with Internal Capacitors
Pages / Page6 / 1 — Miniature Ceramic Resonator. 6.0 x 3.0 x 1.8 mm. RoHS/RoHS II Compliant. …
File Format / SizePDF / 678 Kb
Miniature Ceramic Resonator. 6.0 x 3.0 x 1.8 mm. RoHS/RoHS II Compliant. Pb in ceramic, exemption (7c-I)
Datasheet AWSCR-CPLB Abracon
Miniature Ceramic Resonator 6.0 x 3.0 x 1.8 mm
AWSCR-CPLB
RoHS/RoHS II Compliant Pb in ceramic, exemption (7c-I) This product is not Moisture Sensitive - MSL = 1 Features Applications
Industry standard footprint
Metering systems
Low resonance impedance
Remote control
Built-in capacitance options
Microprocessor
Wide operating temperatures in extended
Industrial control industry range
Electric appliances
Electrical Specifications Parameters Min Typ. Max Units Notes
Frequency Range 1.84 12.00 MHz 100 1.84 MHz – 2.99 MHz Resonant Impedance (Ro) 50 Ω 3.00 MHz – 3.49 MHz 30 3.50 MHz – 12.00 MHz 30 1.84 MHz – 8.00 MHz Other options: 10, 15, 22, 33, 39, 47 (Tol 1pF ± 20%) Standard Built-in Capacitance (C1=C2) pF 15 8.01 MHz – 12.00 MHz Other options: 10, 22, 30, 33, 39, 47 (Tol 1pF ± 20%) Frequency Tolerance -0.5 0.5 % -0.4 0.4 % 2.00-8.00 MHz Frequency Stability -0.2 0.2 % 8.01-12.00 MHz Withstanding Voltage 100 V DC, 5 s max (1) D.C. Voltage 6 V Voltage Rating (2) A.C. Voltage 15 Vp-p Insulation Resistance (Ri) 500 MΩ 10V, 1 min Operation Temperature -40 +125 ºC Storage Temperature -55 +125 ºC Aging Rate (Fosc) * -0.1 0.1 % From Initial value * Components shall be left in a chamber of +85 ºC ± 2 ºC for 1000 hours, then measured after leaving in natural condition for 1 hour. 5101 Hidden Creek Ln Spicewood TX 78669 ABRACON IS Phone: 512-371-6159 | Fax: 512-351-8858
REVISED: 04-19-19
ISO9001-2015 For terms and conditions of sales, please visit: CERTIFIED www.abracon.com
