Datasheet AWSCR-CW (Abracon)
Manufacturer | Abracon |
Description | SMD Ceramic Resonator with Internal Capacitors |
Pages / Page | 3 / 1 — 2.5X2.0mm INDUSTRIAL GRADE BUILT-IN CAPACITANCE. CERAMIC RESONATOR. … |
File Format / Size | PDF / 1.8 Mb |
2.5X2.0mm INDUSTRIAL GRADE BUILT-IN CAPACITANCE. CERAMIC RESONATOR. RoHS/RoHS II compliant. Pb in ceramic, exemption (7c-I)
2.5X2.0mm INDUSTRIAL GRADE BUILT-IN CAPACITANCE CERAMIC RESONATOR
AWSCR-CW
RoHS/RoHS II compliant Pb in ceramic, exemption (7c-I) 2.5 x 2.0 x 1.2mm Moisture Sensitivity Level (MSL) – This product is not Moisture Se nsitive - MSL = 1 FEATURES: APPLICATIONS:
• Low resonant impedance • Remote controls, Microprocessor clocks, Mobile • Built-in load capacitors phones, DVD & CD-Roms, Electric appliances • IR reflow capable • Consumer electronics
STANDARD SPECIFICATIONS: Parameters Minimum Typical Maximum Units Notes
Frequency Range 20.00 60.00 MHz 60 20.00 MHz – 25.99 MHz Resonant Impedance (Ro) 50 Ω 26.00 MHz – 35.00 MHz 50 35.01 MHz – 60.00 MHz 10 – 20% 10 10 + 20% 20.00 MHz – 25.99 MHz Built-in Load Capacitance (C1=C2) 5 – 20% 5 5 + 20% pF 26.00 MHz – 35.00 MHz 5 – 20% 5 5 + 20% 35.01 MHz – 60.00 MHz Frequency Tolerance @25 ºC -0.5 0.5 % Frequency Stability @ -25ºC to +85ºC -0.2 0.2 % Withstanding Voltage 50 V DC , 1 min Rating Voltage (1) D.C.Voltage 6 V (2) A.C. Voltage 15 Vp-p. Insulation Resistance 100 MΩ 10V, 1 i m n Operation Temperature -25 85 ºC Storage Temperature -55 85 ºC Aging Rate (Fosc) (10 years) -0.2 0.2 % From Initial Value
OPTIONS AND PART IDENTIFICATION: Frequency Load Capacitance Packaging
Frequency in MHz T: 3000pcs/Reel Contact ABRACON for Built-in Capacitance options Visit www.abracon.com for Terms & Conditions of Sale
Revised: 08.08.14
ABRACON IS ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED tel 949-546-8000 | fax 949-546-8001| www.abracon.com
