Datasheet AWSCR-CW (Abracon) - 2
ManufacturerAbracon
DescriptionSMD Ceramic Resonator with Internal Capacitors
Pages / Page3 / 2 — 2.5X2.0mm INDUSTRIAL GRADE BUILT-IN CAPACITANCE. CERAMIC RESONATOR. …
2.5X2.0mm INDUSTRIAL GRADE BUILT-IN CAPACITANCE. CERAMIC RESONATOR. RoHS/RoHS II compliant. Pb in ceramic, exemption (7c-I)
2.5X2.0mm INDUSTRIAL GRADE BUILT-IN CAPACITANCE CERAMIC RESONATOR RoHS/RoHS II compliant Pb in ceramic, exemption (7c-I)
AWSCR-CW
RoHS/RoHS II compliant Pb in ceramic, exemption (7c-I) 2.5 x 2.0 x 1.2mm TEST CIRCUIT:
Parts shall be measured under a condition (Temp.: 20±15°C, Humidity: 65±20% R.H.) unless the standard condition (Temp: 25±3°C, Humidity: 65±10% R.H.) is regulated to measure X: Ceramic Resonator C1=C2: 10pF ±20% ( 20.00MHz~25.99MHz) 5pF ±20% (26.00MHz~35.00MHz) 5pF ±20% (35.01MHz~60.00MHz)
OUTLINE DIMENSION: Recommended Land Pattern
1.2 max :Land Pattern
Dimension: mm
Visit www.abracon.com for Terms & Conditions of Sale
Revised: 08.08.14
ABRACON IS ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED tel 949-546-8000 | fax 949-546-8001| www.abracon.com
