Datasheet VIC6A (STMicroelectronics) - 2
DescriptionAutomotive Quad-Bands TeseoVI GNSS Module
Pages / Page8 / 2 — Teseo-VIC6A. Module description. 1.1. Block diagram. Figure 1. Block …
File Format / SizePDF / 343 Kb
Teseo-VIC6A. Module description. 1.1. Block diagram. Figure 1. Block schematic. 1.2. Pin configuration. Figure 2. Module pins layout
Teseo-VIC6A Module description 1.1 Block diagram Figure 1 Block schematic 1.2 Pin configuration Figure 2 Module pins layout
Teseo-VIC6A Module description 1 Module description 1.1 Block diagram Figure 1. Block schematic
nRESET TCXO RTC-Crystal Core Power STANDBY_WAKEUP Supply WHEELTICK Teseo VI- STA8600A FWD ANTENNA_SENSE GNSS Core & Subsystem ANTENNA_IN SAW PPS_OUT G6BB ARM – Cortex M7 ANTENNA_EN SENSOR_INT. Main supply IMU Connectivity Power Management SPI Back-up supply UART I2C GPIO
1.2 Pin configuration Figure 2. Module pins layout
13 GND GND 12 14 AntOFF RF_IN 11 15 FWD GND 10 16 GPIO VCC_RF 9 17 Sensor_IRQ nReset 8 18 I2C_SDA ANTENNA_SENS 7 19 I2C_SCL UART-RTS 6
Teseo-VIC6A
20 UART-TX UART-CTX 5 21 UART-RX WHEELTICK 4 22 V_BAT PPS 3 23 VCC GPIO 2 24 GND STANDBY/Wake up 1
DB5477
Rev 2 page 2/8
Document Outline Teseo-VIC6A 1 Module description 1.1 Block diagram 1.2 Pin configuration 1.3 Pin out description 2 Supported GNSS constellations 2.1 GPS 2.2 GLONASS 2.3 BeiDou 2.4 Galileo 2.5 IRNSS 2.6 QZSS 3 Augmentation systems 3.1 Satellite-based augmentation system 3.2 Differential GPS Revision history
