Datasheet FL7740 (ON Semiconductor) - 5
ManufacturerON Semiconductor
DescriptionPWM Controller, Constant Voltage, Primary Side Regulation for Power Factor Correction
Pages / Page15 / 5 — FL7740. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test Conditions. …
File Format / SizePDF / 422 Kb
FL7740. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit. HW Section. PWM Section. Oscillator Section
FL7740 ELECTRICAL CHARACTERISTICS Symbol Parameter Test Conditions Min Typ Max Unit HW Section PWM Section Oscillator Section
(continued) VDD = 18 V and TJ = −40 ~ 125°C unless otherwise specified
IHV−LC Leakage Current after Startup 1 10 A tR−JFET JFET Regulation Time at Startup Design guaranteed 400 500 600 ms VDD−JFET−HL VDD High Limit during JFET Regulation 17.5 19.0 20.5 V VDD−JFET−LL VDD Low Limit during JFET Regulation 15.5 17.0 18.5 V
PWM Section
TON−MIN−MIN Min. Turn−on Time Min. Limit Design guaranteed 0.40 s TON−MIN−MAX Min. Turn−on Time Max. Limit Design guaranteed 2.0 s TON−MAX Max. Turn−on Time Design guaranteed 23.3 s
Oscillator Section
fMAX Max. Frequency 60 65 70 kHz fMIN Min. Frequency 0.72 0.80 0.88 kHz
Current Sense Section
tLEB Leading−Edge Blanking Time Design guaranteed 300 ns tPD Propagation Delay to GATE Design guaranteed 50 100 150 ns
Voltage Sense Section
tDIS−BNK tDIS Blanking Time at VS Sampling Design guaranteed 0.95 1.00 1.05 s VVS−CLAMP VS Clamping Voltage IVS=1 mA −0.1 0.35 V IVS=10 A VREF Reference Voltage 3.465 3.5 3.535 V CVREGULATION CV Regulation Tolerance VVS = 3.5 V, TJ = 25°C −0.7 +0.7 % VVS = 3.5 V, TJ = −40~125°C −1.2 +1.2 gM Transconductance 16 20 24 mho ICOMV−SINK COMV Sink Current VVS = 4 V 8 10 12 A ICOMV−SOURCE COMV Source Current VVS = 3 V 8 10 12 A VCOMV−HGH COMV High Voltage 4.7 V VCOMV−LOW COMV Low Voltage 0.1 V
Start Sequence Section
tSOFT−START Soft Start Time Design guaranteed 25.6 ms tSS1−MIN SS1 Minimum Time Design guaranteed 2 ms tSS1−MAX SS1 Maximum Time Design guaranteed 100 ms tSS21 SS21 Time Design guaranteed 45 ms tSS22 SS22 Maximum Time Design guaranteed 30 ms
Dynamic Section
VDYN−REF−SET DYN Reference Set Threshold 0.72 0.80 0.88 V tDYN−REF−SET DYN Reference Set Time Design guaranteed 5 s VOV−REF5 OV Reference 5 Design guaranteed +20 % VOV−REF4 OV Reference 4 +14 +15 +16 % VOV−REF3 OV Reference 3 +9 +10 +11 % VOV−REF2 OV Reference 2 +4.7 +5.7 +6.7 % VOV−REF1 OV Reference 1 +1.86 +2.86 +3.86 % VUV−REF1 UV Reference 1 −3.86 −2.86 −1.86 % VUV−REF2 UV Reference 2 −6.7 −5.7 −4.7 % VUV−REF3 UV Reference 3 Design guaranteed −10 %
www.onsemi.com 5
