Datasheet MJL3281A, MJL1302A (ON Semiconductor) - 5
Manufacturer | ON Semiconductor |
Description | Complementary Bipolar Power Transistors |
Pages / Page | 6 / 5 — PACKAGE DIMENSIONS. TO−3BPL (TO−264). SCALE 1:2. −B−. −T−. MILLIMETERS. … |
File Format / Size | PDF / 184 Kb |
PACKAGE DIMENSIONS. TO−3BPL (TO−264). SCALE 1:2. −B−. −T−. MILLIMETERS. INCHES. DIM. MIN. MAX. F 2 PL. D 3 PL. GENERIC. MARKING DIAGRAM*
MECHANICAL CASE OUTLINE
PACKAGE DIMENSIONS TO−3BPL (TO−264)
CASE 340G−02 ISSUE J DATE 17 DEC 2004
SCALE 1:2 Q
0.25 (0.010) M T B M
−B− −T−
NOTES: 1. DIMENSIONING AND TOLERANCING PER
C
ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER.
U E MILLIMETERS INCHES N DIM MIN MAX MIN MAX A
28.0 29.0 1.102 1.142
A B
19.3 20.3 0.760 0.800
C
4.7 5.3 0.185 0.209
D
0.93 1.48 0.037 0.058
R L 1 2 3 E
1.9 2.1 0.075 0.083
F
2.2 2.4 0.087 0.102
G
5.45 BSC 0.215 BSC
P H
2.6 3.0 0.102 0.118
K J
0.43 0.78 0.017 0.031
K
17.6 18.8 0.693 0.740
L
11.2 REF 0.411 REF
N
4.35 REF 0.172 REF
P
2.2 2.6 0.087 0.102
W Q
3.1 3.5 0.122 0.137
F 2 PL R
2.25 REF 0.089 REF
G U
6.3 REF 0.248 REF
J W
2.8 3.2 0.110 0.125
D 3 PL H
0.25 (0.010) M T B S
GENERIC MARKING DIAGRAM*
STYLE 1: STYLE 2: STYLE 3: STYLE 4: STYLE 5: PIN 1. GATE PIN 1. BASE PIN 1. GATE PIN 1. DRAIN PIN 1. GATE 2. DRAIN 2. COLLECTOR 2. SOURCE 2. SOURCE 2. COLLECTOR 3. SOURCE 3. EMITTER 3. DRAIN 3. GATE 3. EMITTER XXXXXX AYYWW XXXXXX = Specific Device Code A = Location Code YY = Year WW = Work Week *This information is generic. Please refer to device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “ G”, may or may not be present.
DOCUMENT NUMBER: 98ASB42780B
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: TO−3BPL (TO−264) PAGE 1 OF 1 onsemi
and are trademarks of Semiconductor Components Industries, LLC dba
onsemi
or its subsidiaries in the United States and/or other countries.
onsemi
reserves the right to make changes without further notice to any products herein.
onsemi
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does
onsemi
assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
onsemi
does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 1994 www.onsemi.com
