Datasheet NCL30000 (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionLED Driver, Dimmable, Power Factor Corrected
Pages / Page25 / 2 — http://onsemi.com. SOIC−8. CASE 751. PIN CONNECTION. MARKING DIAGRAM. …
File Format / SizePDF / 394 Kb
http://onsemi.com. SOIC−8. CASE 751. PIN CONNECTION. MARKING DIAGRAM. Features. ORDERING INFORMATION. Device. Package. Shipping
http://onsemi.com SOIC−8 CASE 751 PIN CONNECTION MARKING DIAGRAM Features ORDERING INFORMATION Device Package Shipping
NCL30000 Power Factor Corrected Dimmable LED Driver The NCL30000 is a switch mode power supply controller intended for low to medium power single stage power factor (PF) corrected LED Drivers. The device is designed to operate in critical conduction mode (CrM) and is suitable for flyback as well as buck topologies.
http://onsemi.com
Constant on time CrM operation is particularly suited for isolated flyback LED applications as the control scheme is straightforward and very high efficiency can be achieved even at low power levels. These are important in LED lighting to comply with regulatory requirements
SOIC−8
and meet overall system luminous efficacy requirements. In CrM, the
CASE 751
switching frequency will vary with line and load and switching losses are low as recovery losses in the output rectifier are negligible since
PIN CONNECTION
the current goes to zero prior to reactivating the main MOSFET switch. MFP VCC The device features a programmable on time limiter, zero current Comp DRV detect sense block, gate driver, trans-conductance error amplifier as Ct GND CS ZCD well as all PWM control circuitry and protection functions required to (Top View) implement a CrM switch mode power supply. Moreover, for high efficiency, the device features low startup current enabling fast, low loss charging of the V
MARKING DIAGRAM
CC capacitor. The current sense protection threshold has been set at 500 mV to minimize power dissipation in the external sense resistor. To support the environmental operation range 8 of Solid State Lighting, the device is specified across a wide junction L0000 temperature range of −40C to 125C. ALYW G
Features
1 Very Low 24 mA Typical Startup Current A = Assembly Location Constant On Time PWM Control L = Wafer Lot Cycle-by-Cycle Current Protection Y = Year W = Work Week Low Current Sense Threshold of 500 mV G = Pb-Free Package Low 2 mA Typical Operating Current Source 500 mA/Sink 800 mA Totem Pole Gate Driver
Reference Design for TRIAC and Trailing Edge Line Dimmers
† Wide Operating Temperature Range NCL30000DR2G SOIC−8 2,500/Tape & Reel No Input Voltage Sensing Requirement (Pb−Free) Enable Function and Overvoltage Protection †For information on tape and reel specifications, These Devices are Pb-Free, Halogen Free/BFR Free and are RoHS including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specifications Compliant Brochure, BRD8011/D.
Typical Applications
LED Driver Power Supplies LED Based Down Lights Commercial and Residential LED Fixtures TRIAC Dimmable LED Based PAR Lamps Power Factor Corrected Constant Voltage Supplies  Semiconductor Components Industries, LLC, 2012
1
Publication Order Number:
September, 2012 − Rev. 1 NCL30000/D
