Datasheet ASR418S2 (Abracon)
Manufacturer | Abracon |
Description | Saw resonator 418 MHz SMD |
Pages / Page | 3 / 1 — SMD ONE PORT SAW RESONATOR. ASR418S2. Pb RoHS. Compliant. 5.0 x 3.5 x … |
File Format / Size | PDF / 1.4 Mb |
SMD ONE PORT SAW RESONATOR. ASR418S2. Pb RoHS. Compliant. 5.0 x 3.5 x 1.4mm. FEATURES:. APPLICATIONS:. STANDARD SPECIFICATIONS
SMD ONE PORT SAW RESONATOR ASR418S2 Pb RoHS Compliant 5.0 x 3.5 x 1.4mm
FEATURES: APPLICATIONS:
• One port SAW • Transmitter • Fundamental • Remote controller • Seam sealed ceramic package assures high reliability • Low insertion loss 1.2dB typical • 50 ohms input/output impedance
STANDARD SPECIFICATIONS Ke y Electrical Specifications Parameters Minimum Typical Maximum Units Notes
Center Frequency (f0) 417.925 418.000 418.075 MHz 418MHz±75kHz Insertion Loss ----- 1.2 1.8 dB ----- 10,730 ----- Unloaded Q Quality Factor ----- 1,400 ----- 50Ω loaded Q Turnover Temperature 25 ----- 50 °C Turnover Frequency ----- F0 ----- MHz Freq. Temp. Coefficient ----- 0.032 ----- ppm/°C Frequency Aging ----- ----- ≤±10 ppm/yr DC Insulation Resistance 1.0 ----- ----- MΩ Motional Resistance R1 ----- 15 23 Ω Motional Inductance L1 ----- 61.3325 ----- uH Motional Capacitance C1 ----- 2.3661 ----- fF Shunt Static Capacitance C0 2.05 2.35 2.65 pF Operation Temperature Range -40 ----- +85 °C Storage Temperature Range -45 ----- +85 °C DC Voltage between terminals ----- ----- ±30 Vdc CW RF Power Dissipation ----- ----- 0 dBm
EQUIVALENT LC MODEL TEST CIRCUIT Visit www.abracon.com for Terms & Conditions of Sale
ABRACON IS
Revised: 02.21.11
ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED tel 949-546-8000 | fax 949-546-8001 | www.abracon.com
