Datasheet MSPM0C110, MSPS003 (Texas Instruments) - 6
Description | Mixed-Signal Microcontrollers |
Pages / Page | 69 / 6 — MSPM0C1104. , MSPM0C1103. www.ti.com. 6 Pin Configuration and Functions … |
File Format / Size | PDF / 2.2 Mb |
MSPM0C1104. , MSPM0C1103. www.ti.com. 6 Pin Configuration and Functions 6.1 Pin Diagrams. Figure 6-1. Pin Diagram Color Coding
MSPM0C1104 , MSPM0C1103
SLASF90C – OCTOBER 2023 – REVISED FEBRUARY 2025
www.ti.com 6 Pin Configuration and Functions 6.1 Pin Diagrams
Power Reset 5-V Tolerant Open-Drain I/O (ODIO)
PA26 / A1 1 20 PA25 / A2 PA26 / A1 1 20 PA25 / A2 PA27 / A0 2 19 PA24 / A3 PA27 / A0 2 19 PA24 / A3 PA28 / A5 3 18 PA23 PA28 / A5 3 18 PA23 PA0 4 17 PA22 / A4 NRST 4 17 PA22 / A4 PA1 / NRST 5 16 PA20 / A6 / SWCLK PA4 5 16 PA20 / A6 / SWCLK VSSOP20 TSSOP20 VDD 6 15 PA19 / SWDIO PA11 6 15 PA19 / SWDIO VSS 7 14 PA18 / A7 VSS 7 14 PA18 / A7 PA2 8 13 PA17 PA2 8 13 PA17 / A9 PA4 9 12 PA16 / A8 VDD 9 12 PA1 PA6 10 11 PA11 PA6 10 11 PA0
Figure 6-2. 20-Pin DGS20 (VSSOP) (Top View) Figure 6-3. 20-Pin PW20 (TSSOP) (Top View)
A0 A1 A2 A3 A27 / A26 / A25 / A24 / A23 P P P P P 20 19 18 17 16 PA28 / A5 1 15 PA22 / A4 PA0 2 14 PA20 / A6 / SWCLK PA1 / NRST 3 13 PA19 / SWDIO WQFN20 PA26 / A1 1 16 PA25 / A2 VDD 4 12 PA18 / A7 VSS 5 PA28 / A5 15 11 PA17 / A9 2 PA24 / A3 PA0 3 14 PA23 6 7 8 9 10 PA1 / NRST 4 13 PA22 / A4 SOT16 VDD 5 12 PA20 / A6 / SWCLK 1 Thermal pad VSS 6 11 PA19 / SWDIO A2 A4 A6 A8 P P P A1 PA2 7 10 P PA18/A7 PA6 8 9 PA17/A9 A16 / P
Figure 6-4. 20-Pin RUK (WQFN) (Top View) Figure 6-5. 16-Pin DYY (SOT) (Top View)
PA27 / A0 1 8 PA24 / A3 PA1 / NRST 2 7 PA20 / A6 / SWCLK WSON VSS 3 6 PA19 / SWDIO PA27 / A0 1 8 PA24 / A3 VDD 4 5 PA0 PA1 / NRST 2 7 PA20 / A6 / SWCLK SOT8 VSS 3 6 PA19 / SWDIO VDD 4 5 PA0 Thermal pad
Figure 6-6. 8-Pin DDF (SOT) (Top View) Figure 6-7. 8-Pin DSG (WSON) (Top View)
6 Submit Document Feedback Copyright © 2025 Texas Instruments Incorporated Product Folder Links: MSPM0C1104 MSPM0C1103 Document Outline 1 Features 2 Applications 3 Description 4 Functional Block Diagram Table of Contents 5 Device Comparison 6 Pin Configuration and Functions 6.1 Pin Diagrams 6.2 Pin Attributes 6.3 Signal Descriptions 6.4 Connections for Unused Pins 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Supply Current Characteristics 7.5.1 RUN/SLEEP Modes 7.5.2 STOP/STANDBY Modes 7.5.3 SHUTDOWN Mode 7.6 Power Supply Sequencing 7.6.1 POR and BOR 7.6.2 Power Supply Ramp 7.7 Flash Memory Characteristics 7.8 Timing Characteristics 7.9 Clock Specifications 7.9.1 System Oscillator (SYSOSC) 7.9.2 Low Frequency Oscillator (LFOSC) 7.10 Digital IO 7.10.1 Electrical Characteristics 7.10.2 Switching Characteristics 7.11 ADC 7.11.1 Electrical Characteristics 7.11.2 Switching Characteristics 7.11.3 Linearity Parameters 7.11.4 Typical Connection Diagram 7.12 Temperature Sensor 7.13 VREF 7.13.1 Voltage Characteristics 7.13.2 Electrical Characteristics 7.14 I2C 7.14.1 I2C Characteristics 7.14.2 I2C Filter 7.14.3 I2C Timing Diagram 7.15 SPI 7.15.1 SPI 7.15.2 SPI Timing Diagrams 7.16 UART 7.17 TIMx 7.18 Windowed Watchdog Characteristics 7.19 Emulation and Debug 7.19.1 SWD Timing 8 Detailed Description 8.1 CPU 8.2 Operating Modes 8.2.1 Functionality by Operating Mode (MSPM0C110x) 8.3 Power Management Unit (PMU) 8.4 Clock Module (CKM) 8.5 DMA 8.6 Events 8.7 Memory 8.7.1 Memory Organization 8.7.2 Peripheral File Map 8.7.3 Peripheral Interrupt Vector 8.8 Flash Memory 8.9 SRAM 8.10 GPIO 8.11 IOMUX 8.12 ADC 8.13 Temperature Sensor 8.14 VREF 8.15 CRC 8.16 UART 8.17 SPI 8.18 I2C 8.19 WWDT 8.20 Timers (TIMx) 8.21 Device Analog Connections 8.22 Input/Output Diagrams 8.23 Serial Wire Debug Interface 8.24 Device Factory Constants 8.25 Identification 9 Applications, Implementation, and Layout 9.1 Typical Application 9.1.1 Schematic 10 Device and Documentation Support 10.1 Device Nomenclature 10.2 Tools and Software 10.3 Support Resources 10.4 Trademarks 10.5 Electrostatic Discharge Caution 10.6 Glossary 11 Revision History 12 Mechanical, Packaging, and Orderable Information
