Datasheet MSPM0C110, MSPS003 (Texas Instruments) - 7
Description | Mixed-Signal Microcontrollers |
Pages / Page | 69 / 7 — MSPM0C1104. , MSPM0C1103. www.ti.com. PA24. PA0. PA1/. PA27. NRST. PA20. … |
File Format / Size | PDF / 2.2 Mb |
MSPM0C1104. , MSPM0C1103. www.ti.com. PA24. PA0. PA1/. PA27. NRST. PA20. VDD. PA19. VSS. Figure 6-8. 8-Pin YCJ (DSBGA) (Bumps Down View)
MSPM0C1104 , MSPM0C1103 www.ti.com
SLASF90C – OCTOBER 2023 – REVISED FEBRUARY 2025
1 2 A PA24 PA0 B PA1/ PA27 NRST C PA20 VDD D PA19 VSS Figure 6-8. 8-Pin YCJ (DSBGA) (Bumps Down View)
Copyright © 2025 Texas Instruments Incorporated Submit Document Feedback 7 Product Folder Links: MSPM0C1104 MSPM0C1103 Document Outline 1 Features 2 Applications 3 Description 4 Functional Block Diagram Table of Contents 5 Device Comparison 6 Pin Configuration and Functions 6.1 Pin Diagrams 6.2 Pin Attributes 6.3 Signal Descriptions 6.4 Connections for Unused Pins 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Supply Current Characteristics 7.5.1 RUN/SLEEP Modes 7.5.2 STOP/STANDBY Modes 7.5.3 SHUTDOWN Mode 7.6 Power Supply Sequencing 7.6.1 POR and BOR 7.6.2 Power Supply Ramp 7.7 Flash Memory Characteristics 7.8 Timing Characteristics 7.9 Clock Specifications 7.9.1 System Oscillator (SYSOSC) 7.9.2 Low Frequency Oscillator (LFOSC) 7.10 Digital IO 7.10.1 Electrical Characteristics 7.10.2 Switching Characteristics 7.11 ADC 7.11.1 Electrical Characteristics 7.11.2 Switching Characteristics 7.11.3 Linearity Parameters 7.11.4 Typical Connection Diagram 7.12 Temperature Sensor 7.13 VREF 7.13.1 Voltage Characteristics 7.13.2 Electrical Characteristics 7.14 I2C 7.14.1 I2C Characteristics 7.14.2 I2C Filter 7.14.3 I2C Timing Diagram 7.15 SPI 7.15.1 SPI 7.15.2 SPI Timing Diagrams 7.16 UART 7.17 TIMx 7.18 Windowed Watchdog Characteristics 7.19 Emulation and Debug 7.19.1 SWD Timing 8 Detailed Description 8.1 CPU 8.2 Operating Modes 8.2.1 Functionality by Operating Mode (MSPM0C110x) 8.3 Power Management Unit (PMU) 8.4 Clock Module (CKM) 8.5 DMA 8.6 Events 8.7 Memory 8.7.1 Memory Organization 8.7.2 Peripheral File Map 8.7.3 Peripheral Interrupt Vector 8.8 Flash Memory 8.9 SRAM 8.10 GPIO 8.11 IOMUX 8.12 ADC 8.13 Temperature Sensor 8.14 VREF 8.15 CRC 8.16 UART 8.17 SPI 8.18 I2C 8.19 WWDT 8.20 Timers (TIMx) 8.21 Device Analog Connections 8.22 Input/Output Diagrams 8.23 Serial Wire Debug Interface 8.24 Device Factory Constants 8.25 Identification 9 Applications, Implementation, and Layout 9.1 Typical Application 9.1.1 Schematic 10 Device and Documentation Support 10.1 Device Nomenclature 10.2 Tools and Software 10.3 Support Resources 10.4 Trademarks 10.5 Electrostatic Discharge Caution 10.6 Glossary 11 Revision History 12 Mechanical, Packaging, and Orderable Information
