Datasheet AWCR-RS (Abracon)
ManufacturerAbracon
DescriptionLow Profile Leaded Industrial Grade Built-In Capacitance Ceramic Resonator
Pages / Page2 / 1 — LOW PROFILE LEADED INDUSTRIAL GRADE. AWCR-RS. BUILT-IN CAPACITANCE …
LOW PROFILE LEADED INDUSTRIAL GRADE. AWCR-RS. BUILT-IN CAPACITANCE CERAMIC RESONATOR. RoHS/RoHS II Compliant. FEATURES:
Datasheet AWCR-RS Abracon
LOW PROFILE LEADED INDUSTRIAL GRADE AWCR-RS BUILT-IN CAPACITANCE CERAMIC RESONATOR
AWCR-RS
Pb in ceramic, exemption (7c-I) Size Varies | | | | | | | | | | | | | | |
FEATURES: APPLICATIONS:
• Built-in capacitors save space & components. • Microprocessor clocks. • Industrial controllers. • Low cost timing solution. • Electric appliances. • General timing. • Small size, Light weight. • Remote controls.
ELECTRICAL CHARACTERISTICS: Parameters Minimum Typical Maximum Units Notes
Frequency Range 6.01 12.50 MHz Resonant Impedance (Ro) 25 Ω Frequency Tolerance -0.5 +0.5 % Frequency Stability -0.3 +0.3 % -25ºC to +85ºC Withstanding Voltage 100 Vdc 5 secs D.C. Voltage 6 Vdc Rating Voltage A.C. Voltage 15 Vp-p. Load Capacitance 12 15 18 pF Insulation Resistance 500 MΩ 10Vdc, 1min Operation Temperature -25 +85 ºC Storage Temperature -40 +85 ºC Aging Rate (Fosc) -0.3 0.3 % From initial value
TEST CONDITION AND TEST CIRCUIT:
Parts shall be mea sured under a cond ition X: Ceramic Resonator (Temp.: 20±15°C, Humidity: 65±20% R.H.) C1=C2 unless the standard con dition (Temp: 25±3°C, 1.Input 2.Ground 3.Output Humidity: 65±10% R.H.) is regulated to me asure
OPTIONS & PART IDENTIFICATION:
AWCR - RS - C -
Frequency Load Capacitance in pF Packaging
Frequency in MHz Contact ABRACON for Blank: Bulk Load Capacitance options A: AMMO package* if not standard *AMMO package lead length 13.5mm Visit www.abracon.com for Terms & Conditions of Sale Revised: 05.07.13 ABRACON IS ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED tel 949-546-8000 | fax 949-546-8001| www.abracon.com
