Datasheet AWCR-RS (Abracon) - 2
ManufacturerAbracon
DescriptionLow Profile Leaded Industrial Grade Built-In Capacitance Ceramic Resonator
Pages / Page2 / 2 — L LOW. OW PR P. O R. AW O. C F. R-ILLEEA. RS S L. Der E. E A. ies DED. …
L LOW. OW PR P. O R. AW O. C F. R-ILLEEA. RS S L. Der E. E A. ies DED. LOW PROFILE LEADED INDUSTRIA. IND DUS. USTLT. RI RI. OW AG. P LR. R OG. AF R
L LOW OW PR P O R AW O C F R-ILLEEA RS S L Der E E A ies DED LOW PROFILE LEADED INDUSTRIA IND DUS USTLT RI RI OW AG P LR R OG AF R
L LOW OW PR P O R FI AW O L C F E R-ILLEEA RS S L Der E E A D ies DED LOW PROFILE LEADED INDUSTRIA IN IND DUS USTLT RI RI AL OW AG P LR R OG AF R DE ILE LEA DED INDUSTRIAL GR A B DE B UILT-IN L UILT- GRADE IN AWCR-RS BUILT-IN CA ADE BUILT-IN P C ACI C A A PA C T PCI APANCE CERAMIC R AC TA I ACT NI A T N ANCE CE CE CERA M CE CE R R AA IC MM IC E IC SONATOR RESONATOR RES ONATOR
July 19th AWCR-RS
RESONATOR
, 2012
5.5 x 3.0 x 5.0mm RoHS/RoHS II Compliant
ssue: July 19th, 2012
5.5 x 3.0 x 5.0 mm
Pb in ceramic, exemption (7c-I) Size Varies uly 19th, 2012
5.5 x 3.0 x 5.0mm
| | | | | | | | | | | | | | | ) of (10)
Abracon Drawin g # 452751
Revision #: C of Pag e( 10 (6) of (10)
Abracon Draw ing # 452751
Revision #: C
OUTLINE DRAWING:
Abracon Drawing # 452751
Revision #: C
mensions ne Dimensions Bulk Pack mensions AMMO Pack AM A M M O M P O ac P k: a ck: : AM MO Pack: Pack: Dimensions: mm Packaging: Bulk:
500pcs/plastic bag
AMMO:
2000pcs/box
Note:
upon opening the original packaging, it is recommended that the product be used within 1 year. If the prod-
Dimension: mm
uct will not be used within 1 year
Dimension: mm
, it is recommended that the product be re-sealed in airtight packaging according to MSL
Dime nsion: m
1 requirements to maintain solderabilit
m
y.
CAUTION
(1) Do not apply excess mechanical stress to the component body or terminations. Do not attempt to re-form or bend the components as this will cause damage to the component. (2) This component is not hermetically sealed. Do not clean or wash the component. (3) Reflow Soldering: Do not use strong acidity flux, such as flux with chlorine content of greater than 0.2wt% during Reflow Soldering. (4) Do not expose the component to open flame. (5) This specification applies to the functionality of the component as a single unit. (6) Storage Conditions: If the product is to be stored for a period greater than 1 year after the Delivery Date, it is recommended that customers confirm the solderability and characteristics for the product prior to use. (7) This product is not recommended for use in the following applications: Automotive, Medical, Military, Safety, or any other high- reliabilit , y life dependant applications. ContactAbracon Corporation p rior to using this product when in doubt.
mm ATTENTION:
Abracon Corporation’s products are COTS – Commercial-Off-The-Shelf products; suitable for Commercial, Industrial and, where designated, Automotive Applica- tions. Abracon’s products are not specifically designed for Military, Aviation, Aerospace, Life-dependant Medical applications or any application requiring high reliability where component failure could result in loss of life and/or property. For applications requiring high reliability and/or presenting an extreme operating environment, written consent and authorization from Abracon Corporation is required. Please contact Abracon Corporation for more information. Visit www.abracon.com for Terms & Conditions of Sale Revised: 05.07.13 ABRACON IS ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED tel 949-546-8000 | fax 949-546-8001| www.abracon.com
