Datasheet EL7515 (Renesas)
ManufacturerRenesas
DescriptionHigh Frequency PWM Step-Up Regulator
Pages / Page9 / 1 — NOT RECOMMEN. DED FOR NEW DESIGNS. NO RECOMMENDED REPLACEMENT. contact …
File Format / SizePDF / 564 Kb
NOT RECOMMEN. DED FOR NEW DESIGNS. NO RECOMMENDED REPLACEMENT. contact our Technical. Support Center at
Datasheet EL7515 Renesas
NOT RECOMMEN
DATASHEET
DED FOR NEW DESIGNS NO RECOMMENDED REPLACEMENT contact our Technical
EL7515
Support Center at 1-888-INTERSIL or www.intersil.com/tsc
FN7120 High Frequency PWM Step-Up Regulator Rev 2.00 August 10, 2007 The EL7515 is a high frequency, high efficiency step-up
Features
DC/DC regulator operated at fixed frequency PWM mode. With an integrated 1.4A MOSFET, it can deliver up to 600mA • Up to 92% efficiency output current at up to 92% efficiency. The adjustable • Up to 600mA IOUT switching frequency is up to 1.2MHz, making it ideal for DSL • 4.5V < V applications. OUT < 17V • 1.8V < V When shut down, it draws <1µA of current. This feature, IN < 13.2V along with the minimum starting voltage of 1.8V, makes it • Up to 1.2MHz adjustable frequency suitable for portable equipment powered by one Lithium Ion, • <1µA shutdown current 3 to 4 NiMH cells, or 2 cells of alkaline battery. • Adjustable soft-start The EL7515 is available in a 10 Ld MSOP package, with • Low battery detection maximum height of 1.1mm. With proper external components, the whole converter takes less than 0.25in2 • Internal thermal protection PCB space. • 1.1mm max height 10 Ld MSOP package This device is specified for operation over the full -40°C to • Pb-Free available (RoHS compliant) +85°C temperature range.
Applications Pinout
• 3V to 5V and 12V converters
EL7515 (10 LD MSOP)
• 5V to 12V converters TOP VIEW • TFT-LCD
PGND 1 10 LX
• DSL
SGND 2 9 VDD
• Portable equipment
RT 3 8 FB
• Desktop equipment
EN 4 7 SS Ordering Information LBI 5 6 LBO PART PART PKG. NUMBER MARKING PACKAGE DWG. #
EL7515IY e 10 Ld MSOP MDP0043 EL7515IY-T7* e 10 Ld MSOP MDP0043 EL7515IY-T13* e 10 Ld MSOP MDP0043 EL7515IYZ BAAAR 10 Ld MSOP MDP0043 (Note) (Pb-free) EL7515IYZ-T7* BAAAR 10 Ld MSOP MDP0043 (Note) (Pb-free) EL7515IYZ-T13* BAAAR 10 Ld MSOP MDP0043 (Note) (Pb-free) *Please refer to TB347 for details on reel specifications. NOTE: These Intersil Pb-free plastic packaged products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate PLUS ANNEAL - e3 termination finish, which is RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. FN7120 Rev 2.00 Page 1 of 9 August 10, 2007
