Datasheet LTC1392 (Analog Devices) - 4
DescriptionMicropower Temperature, Power Supply and Differential Voltage Monitor
Pages / Page12 / 4 — RECOM ENDED OPERATING CONDITIONS. Note 4:. Note 1:. Note 5:. Note 2:. …
File Format / SizePDF / 259 Kb
RECOM ENDED OPERATING CONDITIONS. Note 4:. Note 1:. Note 5:. Note 2:. Note 3:. Note 6:. Note 7:. TYPICAL PERFORMANCE CHARACTERISTICS
RECOM ENDED OPERATING CONDITIONS Note 4: Note 1: Note 5: Note 2: Note 3: Note 6: Note 7: TYPICAL PERFORMANCE CHARACTERISTICS
LTC1392
WW U U U U RECOM ENDED OPERATING CONDITIONS
The ● denotes specifications which apply over the operating temperature
Note 4:
Temperature integral nonlinearity is defined as the deviation of the range (0°C ≤ TA ≤ 70°C for commercial grade and – 40°C ≤ TA ≤ 85°C for A/D code versus temperature curve from the best-fit straight line over the industrial grade). device’s rated temperature range.
Note 1:
Absolute maximum ratings are those values beyond which the life
Note 5:
Voltage integral nonlinearity is defined as the deviation of a code of the device may be impaired. from a straight line passing through the actual end points of the transfer
Note 2:
All voltage values are with respect to GND. curve.
Note 3:
Testing done at V
Note 6:
Channel leakage current is measured after the channel selection. CC = 5V, CLK = 250kHz and TA = 25°C unless otherwise specified.
Note 7:
See guaranteed temperature limit curves vs temperature range on the first page of this data sheet.
W U TYPICAL PERFORMANCE CHARACTERISTICS Differential Nonlinearity Integral Nonlinearity Power Supply Voltage Mode Power Supply Voltage Mode Differential Nonlinearity
1.0 1.0 1.0 fCLK = 250kHz fCLK = 250kHz Full Scale = 1V TA = 25°C TA = 25°C fCLK = 250kHz TA = 25°C 0.5 0.5 0.5 VCC = 5V 0 0 0 –0.5 –0.5 –0.5 INTEGRAL NONLINEARITY ERROR (LSB) DIFFERENTIAL NONLINEARITY ERROR (LSB) DIFFERENTIAL NONLINEARITY ERROR (LSB) –1.0 –1.0 –1.0 256 320 384 448 512 576 640 704 768 832 256 320 384 448 512 576 640 704 768 832 0 128 256 384 512 640 768 896 1024 CODE CODE CODE 1392 G01 1392 G02 1392 G03
Integral Nonlinearity Differential Nonlinearity Integral Nonlinearity
1.0 1.0 1.0 Full Scale = 1V Full Scale = 0.5V Full Scale = 0.5V fCLK = 250kHz f f CLK = 250kHz CLK = 250kHz TA = 25°C T T A = 25°C A = 25°C 0.5 VCC = 5V 0.5 V V CC = 5V 0.5 CC = 5V 0 0 0 –0.5 –0.5 –0.5 INTEGRAL NONLINEARITY ERROR (LSB) INTEGRAL NONLINEARITY ERROR (LSB) DIFFERENTIAL NONLINEARITY ERROR (LSB) –1.0 –1.0 –1.0 0 128 256 384 512 640 768 896 1024 0 128 256 384 512 640 768 896 1024 0 128 256 384 512 640 768 896 1024 CODE CODE CODE 1392 G04 1392 G05 1392 G06 4
