Datasheet LTC1392 (Analog Devices) - 5
DescriptionMicropower Temperature, Power Supply and Differential Voltage Monitor
Pages / Page12 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Thermal Response in Stirred Oil …
File Format / SizePDF / 259 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Thermal Response in Stirred Oil Bath. Thermal Response in Still Air
TYPICAL PERFORMANCE CHARACTERISTICS Thermal Response in Stirred Oil Bath Thermal Response in Still Air
LTC1392
W U TYPICAL PERFORMANCE CHARACTERISTICS Thermal Response in Stirred Oil Bath Thermal Response in Still Air Supply Current vs Sample Rate
70 70 1000 65 VCC = 5V VCC = 5V CS LOW BETWEEN SAMPLES 65 60 60 100 55 µA) °C) 55 °C) CS HIGH BETWEEN 50 50 SAMPLES 45 45 10 40 40 N8 TEMPERATURE ( 35 TEMPERATURE ( 35 S8 N8 SUPPLY CURRENT ( 1 30 30 VCC = 5V S8 f 25 CLK = 250kHz 25 TA = 25°C 20 0.1 20 0 5 10 15 20 25 30 0 50 250 300 0.1 1 10 100 1k 10k 100k 100 150 200 TIME (SEC) SAMPLE FREQUENCY (Hz) TIME (SEC) 1392 G09 1392 G07 1392 G08
U U U PIN FUNCTIONS DIN (Pin 1):
Digital Input. The A/D configuration word is
GND (Pin 5):
Ground Pin. GND should be tied directly to shifted into this input. an analog ground plane.
DOUT (Pin 2):
Digital Output. The A/D result is shifted out
+VIN (Pin 6):
Positive Analog Differential Input. The pin of this output. can be used as a single-ended input by grounding – VIN.
CLK (Pin 3):
Shift Clock. This clock synchronizes the serial
– VIN (Pin 7):
Negative Analog Differential Input. The input data. must be free from noise.
CS (Pin 4):
Chip Select Input. A logic low on this input
VCC (Pin8):
Positive Supply. This supply must be kept free enables the LTC1392. from noise and ripple by bypassing directly to the ground plane.
W BLOCK DIAGRAM
3 CLK VREF = 2.42V INPUT 1 VREF = 1V D SHIFT BANDGAP IN REGISTER VREF = 0.5V 2 D SERIAL OUT PORT 10-BIT CAPACITIVE DAC 10 TEMPERATURE BITS + SENSOR GND – COMP 10-BIT ANALOG VCC + SAR INPUT VREF – MUX 6 C +V SAMPLE IN + 7 –VIN – CONTROL 4 CS 8 5 AND TIMING V GND LTC1392 • BD CC 5
