20 /7 — Data Sheet. AD8338. 1.0. 0.5. ) V. –0.5. R ( –1.0. O O. RRO. OLTA. D T. …
Revision
B
PDF / 483 Kb
Data Sheet. AD8338. 1.0. 0.5. ) V. –0.5. R ( –1.0. O O. RRO. OLTA. D T. –1.5. N E. T V. 10kHz. RRE E. G –2.0. 100kHz. 1MHz. OFFS. 2MHz. –2.5. 4MHz. –40°C. 8MHz. +25°C
Data SheetAD83381.050.5430) VUT2–0.5mPB)(dUTGE1R ( –1.0O O0RROOLTAD T–1.5N ET V–1AI10kHzERRE EG –2.0100kHzF1MHz–2OFFSRE2MHz–2.54MHz–3–40°C8MHz+25°C–3.010MHz 12MHz–4+85°C14MHz+105°C–3.5–50.10.20.30.40.50.60.70.80.91.01.1 007 0.10.20.30.40.50.60.70.80.91.01.1 012 VGAIN (V) 1279- V 1 GAIN (V) 11279- Figure 10. Gain Error vs. VGAIN over Frequency Figure 13. Differential Offset Voltage vs. VGAIN, Offset Null On 303503002525020) (ΩDIFFERENTIALs) nE 200(C15NAYAL150DEIMPED10100550SINGLE-ENDED00 12 100k1M10M100M 10 1 100k1M10M100M 1 FREQUENCY (Hz) 1279- 1279- 1 FREQUENCY (Hz) 1 Figure 11. Group Delay vs. Frequency Figure 14. Output Impedance vs. Frequency 20OFFSET NULL ENABLED RELATIVE TO OUTPUT60VGAIN = 0.6V0N = 962GAIN = 100050–20SB)TdGAIN = 100HI40R (F–40GAIN = 10R ORRO E30BE–60GAIN = 1NUMANCE20BAL–8010–1000–120–3–2–1012 111 100k1M10M100M 015 DIFFERENTIAL OFFSET VOLTAGE (mV) 11279- FREQUENCY (Hz) 11279- Figure 12. Differential Offset Voltage Histogram Figure 15. Output Balance Error vs. Frequency Rev. A | Page 7 of 20 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications AC Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Introduction Overall Structure of the AD8338 VGA Core Normal Operating Conditions INPR, INMR, INPD, and INMD Pins FBKP, FBKM, OUTP, and OUTM Pins Linear-in-dB Gain Control, GAIN Pin Inversion of the Gain Slope, MODE Pin Offset Correction Circuit, OFSN Pin AGC Circuit, VAGC Pin Internal Reference, Pin VREF Explanation of the Gain Function Effects of Using External Resistors Adjusting The Output Common-Mode Voltage Applications Information Simple On-Off Keyed (OOK) Receiver Interfacing the AD8338 to an ADC Outline Dimensions Ordering Guide
