Datasheet LTC3459 (Analog Devices) - 9
Description10V Micropower Synchronous Boost Converter in ThinSOT
Pages / Page12 / 9 — TYPICAL APPLICATIONS. Charging a SuperCap®. 5V from Li-Ion Input. 10V …
File Format / SizePDF / 226 Kb
TYPICAL APPLICATIONS. Charging a SuperCap®. 5V from Li-Ion Input. 10V from 3.3V or 5V Input
TYPICAL APPLICATIONS Charging a SuperCap® 5V from Li-Ion Input 10V from 3.3V or 5V Input
LTC3459
Very low operating quiescent current and synchronous The LTC3459 is designed to control peak inductor current operation allow for greater than 85% conversion effi ciency when VIN is greater than or less than VOUT. This allows in many applications. Lower output voltages will result in current to be controlled during start-up in a boost applica- lower effi ciencies since the N- and P-channel RDS(ON)s tion, for example, or VOUT to be regulated below VIN when will increase. The switching frequency and output power powered from a fresh battery. Peak current control makes capability of the LTC3459 are also dependant on input and the LTC3459 an ideal candidate for charging a back-up output voltages. source such as a SuperCap. Figure 5 shows an application where the LTC3459 is used to charge a two-farad, 5V Su-
perCap from a 3.3V input. A NiCd battery could be charged SuperCaps have become a popular alternative to NiCd by the LTC3459 as well, but that application may require batteries as back-up power sources in portable equip- additional circuitry for proper charge termination. ment. Capacitance values of one farad and higher are When VOUT is less than ~3.5V, the body of the internal achievable in small package sizes with leakage currents synchronous P-channel MOSFET rectifi er is connected to in the low microamps. SuperCaps are typically charged VIN, and the SW pin rises a diode above VIN when current at low currents for several minutes until they reach the is delivered to the load. While effi ciency is compromised required back-up voltage. in this mode of operation, current to the SuperCap is
15μH* 100 VOUT = 5V VIN = 4.2V SW 90 V V IN V OUT IN VOUT 2.5V TO 4.2V 5V 1M 47pF LTC3459 + 80 VIN = 2.5V Li-Ion 1μF 4.7μF OFF ON SHDN FB BATTERY GND 332k 70 EFFICIENCY (%) 3459 TA04a *COILCRAFT DO3314 60 50 0.01 0.1 1 10 100 ILOAD (mA) 3459 TA04b
100 33μH* VOUT = 10V SW 90 V V V IN IN = 5V V OUT IN V 3.3V TO 5V OUT 10V 2M 47pF LTC3459 80 VIN = 3.3V 1μF OFF ON SHDN FB 4.7μF GND 280k 70 EFFICIENCY (%) 3459 TA05a *COILCRAFT DO3314 60 50 0.01 0.1 1 10 100 ILOAD (mA) 3459 TA05b 3459fc 9
