Datasheet MAX917, MAX918, MAX919, MAX920 (Maxim) - 4
ManufacturerMaxim
DescriptionSOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without Reference
Pages / Page15 / 4 — SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without …
Revision2
File Format / SizePDF / 226 Kb
SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without Reference ELECTRICAL CHARACTERISTICS—MAX919/MAX920 (continued)
(VCC = +5V, VEE = 0V, VCM = 0V, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Input Offset Current IOS 10 pA Power-Supply Rejection Ratio PSRR VCC = 1.8V to 5.5V 0.1 1 mV/V Common-Mode Rejection Ratio CMRR (VEE - 0.2V) ≤ VCM ≤ (VCC + 0.2V) 0.5 3 mV/V MAX919 only, V TA = +25°C CC = 190 400 5V, ISOURCE = 8mA TA = TMIN to TMAX 500 Output-Voltage Swing High VCC - VOH mV MAX919 only, VCC = TA = +25°C 55 200 1.8V, ISOURCE = 1mA TA = TMIN to TMAX 300 V TA = +25°C 190 400
MAX917–MAX920
CC = 5V, ISINK = 8mA TA = TMIN to TMAX 500 Output-Voltage Swing Low VOL mV VCC = 1.8V, TA = +25°C 55 200 ISINK = 1mA TA = TMIN to TMAX 300 Output Leakage Current ILEAK MAX920 only, VO = 5.5V 0.001 1 µA VCC = 5V 95 Sourcing, VO = VEE VCC = 1.8V 8 Output Short-Circuit Current ISC mA VCC = 5V 98 Sinking, VO = VCC VCC = 1.8V 10 High-to-Low Propagation Delay VCC = 1.8V 17 tPD- µs (Note 4) VCC = 5V 22 VCC = 1.8V 30 MAX919 only VCC = 5V 95 Low-to-High Propagation Delay V t CC = 1.8V PD+ µs (Note 4) RPULLUP = 100kΩ 35 MAX920 only VCC = 5V RPULLUP = 100kΩ 120 Rise Time tRISE MAX919 only, CL = 15pF 6 µs Fall Time tFALL CL = 15pF 4 µs Power-Up Time tON 1.2 ms
Note 1:
All specifications are 100% tested at TA = +25°C. Specification limits over temperature (TA = TMIN to TMAX) are guaranteed by design, not production tested.
Note 2:
VOS is defined as the center of the hysteresis band at the input.
Note 3:
The hysteresis-related trip points are defined as the edges of the hysteresis band, measured with respect to the center of the band (i.e., VOS) (Figure 2).
Note 4:
Specified with an input overdrive (VOVERDRIVE) of 100mV, and load capacitance of CL = 15pF. VOVERDRIVE is defined above and beyond the offset voltage and hysteresis of the comparator input. For the MAX917/MAX918, reference voltage error should also be added.
4 _______________________________________________________________________________________
