Datasheet MAX917, MAX918, MAX919, MAX920 (Maxim) - 5
Manufacturer | Maxim |
Description | SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without Reference |
Pages / Page | 15 / 5 — SOT23, 1.8V, Nanopower, Beyond-the-Rails. Comparators With/Without … |
Revision | 2 |
File Format / Size | PDF / 226 Kb |
SOT23, 1.8V, Nanopower, Beyond-the-Rails. Comparators With/Without Reference. MAX917–MAX920
SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without Reference MAX917–MAX920 Typical Operating Characteristics
(VCC = +5V, VEE = 0V, CL = 15pF, VOVERDRIVE = 100mV, TA = +25°C, unless otherwise noted.)
MAX917/MAX918 MAX919/MAX920 SUPPLY CURRENT vs. SUPPLY CURRENT vs. MAX917/MAX918 SUPPLY VOLTAGE AND TEMPERATURE SUPPLY VOLTAGE AND TEMPERATURE SUPPLY CURRENT vs. TEMPERATURE
900 600 900 TA = +85°C 850 800 MAX917-920 toc01 MAX917-920 toc02 MAX917-920 toc03 V T 800 CC = 5V A = +85°C 500 750 TA = +25°C V 700 CC = 3V T 700 A = +25°C 650 400 VCC = 1.8V SUPPLY CURRENT (nA) SUPPLY CURRENT (nA) SUPPLY CURRENT (nA) 600 TA = -40°C T 600 A = -40°C 550 500 300 500 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -40 -15 10 35 60 85 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) TEMPERATURE (°C)
MAX917/MAX918 MAX919/MAX920 MAX919/MAX920 SUPPLY CURRENT vs. SUPPLY CURRENT vs. SUPPLY CURRENT vs. TEMPERATURE OUTPUT TRANSITION FREQUENCY OUTPUT TRANSITION FREQUENCY
550 16 14 14 VCC = 5V V 12 CC = 5V 500 MAX917-920 toc04 12 MAX917-920 toc05 MAX917-920 toc06 μA) 10 μA) VCC = 5V 450 10 8 8 V V CC = 3V CC = 3V 6 400 V V CC = 1.8V CC = 3V 6 SUPPLY CURRENT (nA) SUPPLY CURRENT ( SUPPLY CURRENT ( 4 4 350 2 2 VCC = 1.8V VCC = 1.8V 300 0 0 -40 -15 10 35 60 85 1 10 100 1k 10k 100k 1 10 100 1k 10k 100k TEMPERATURE (°C) OUTPUT TRANSITION FREQUENCY (Hz) OUTPUT TRANSITION FREQUENCY (Hz)
OUTPUT-VOLTAGE LOW vs. SINK CURRENT MAX917/MAX919 OUTPUT-VOLTAGE LOW vs. SINK CURRENT AND TEMPERATURE OUTPUT-VOLTAGE HIGH vs. SOURCE CURRENT
450 600 0.6 VCC = 1.8V 400 VCC = 1.8V VCC = 3V 500 0.5 350 MAX917-920 toc07 MAX917-920 toc08 MAX917-920 toc09 V V CC = 3V VCC = 5V CC = 5V 300 400 TA = +25°C 0.4 (V) 250 (mV) OH (mV) 300 T - V 0.3 V OL 200 V OL A = +85°C CC V 150 200 0.2 TA = -40°C 100 100 0.1 50 0 0 0 0 2 4 6 8 10 12 14 16 0 2 4 6 8 10 12 14 16 0 2 4 6 8 10 12 14 16 18 20 SINK CURRENT (mA) SINK CURRENT (mA) SOURCE CURRENT (mA)
_______________________________________________________________________________________ 5
