Datasheet MAX917, MAX918, MAX919, MAX920 (Maxim) - 6
Manufacturer | Maxim |
Description | SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without Reference |
Pages / Page | 15 / 6 — SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without … |
Revision | 2 |
File Format / Size | PDF / 226 Kb |
SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without Reference Typical Operating Characteristics (continued)
(VCC = +5V, VEE = 0V, CL = 15pF, VOVERDRIVE = 100mV, TA = +25°C, unless otherwise noted.)
MAX917/MAX919 MAX917/MAX919 OUTPUT-VOLTAGE HIGH vs. SHORT-CIRCUIT SINK CURRENT SHORT-CIRCUIT SOURCE CURRENT SOURCE CURRENT AND TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
0.6 120 140 VCC = 5V 120 0.5 100 VCC = 5V MAX917-920 toc10 MAX917-920 toc11 MAX917-920 toc12 100 0.4 80 TA = +25°C (V) 80 OH - V 0.3 TA = +85°C 60 CC V 60 V CC = 3V 0.2 SINK CURRENT (mA) 40 V SOURCE CURRENT (mA) CC = 3V 40 T
MAX917–MAX920
A = -40°C 0.1 20 20 VCC = 1.8V VCC = 1.8V 0 0 0 -40 -15 10 35 60 85 0 2 4 6 8 10 12 14 16 18 20 -40 -15 10 35 60 85 TEMPERATURE (°C) SOURCE CURRENT (mA) TEMPERATURE (°C)
MAX917/MAX918 OFFSET VOLTAGE vs. TEMPERATURE HYSTERESIS VOLTAGE vs. TEMPERATURE REFERENCE VOLTAGE vs. TEMPERATURE
0.10 5.0 1.246 VCC = 5V 0.09 VCC = 1.8V 4.5 1.245 MAX917-920 toc13 MAX917-920 toc14 MAX917-920 toc15 V 0.08 CC = 3V 4.0 0.07 1.244 (mV) V (mV) CC = 3V V V OS CC = 1.8V 0.06 V HB 3.5 1.243 0.05 REFERENCE VOLTAGE (V) 3.0 1.242 0.04 VCC = 5V 0.03 2.5 1.241 -40 -15 10 35 60 85 -40 -15 10 35 60 85 -40 -15 10 35 60 85 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
MAX917/MAX918 MAX917/MAX918 MAX917/MAX918 REFERENCE VOLTAGE vs. REFERENCE OUTPUT VOLTAGE vs. REFERENCE OUTPUT VOLTAGE vs. SUPPLY VOLTAGE REFERENCE SOURCE CURRENT REFERENCE SINK CURRENT
1.2460 1.2440 1.2460 V V CC = 3V CC = 1.8V 1.2435 1.2455 1.2455 MAX917-920 toc16 MAX917-920 toc17 MAX917-920 toc18 1.2430 VCC = 1.8V 1.2450 V (V) (V) CC = 3V 1.2450 V REF V REF 1.2425 VCC = 5V 1.2445 V REFERENCE VOLTAGE (V) CC = 5V 1.2445 1.2420 1.2440 1.2440 1.2415 1.2435 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0 1 2 3 4 5 6 7 8 9 10 0 1 2 3 4 5 6 7 8 9 10 SUPPLY VOLTAGE (V) SOURCE CURRENT (nA) SINK CURRENT (nA)
6 _______________________________________________________________________________________
