Datasheet MAX917, MAX918, MAX919, MAX920 (Maxim) - 7
Manufacturer | Maxim |
Description | SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without Reference |
Pages / Page | 15 / 7 — SOT23, 1.8V, Nanopower, Beyond-the-Rails. Comparators With/Without … |
Revision | 2 |
File Format / Size | PDF / 226 Kb |
SOT23, 1.8V, Nanopower, Beyond-the-Rails. Comparators With/Without Reference. MAX917–MAX920
SOT23, 1.8V, Nanopower, Beyond-the-Rails Comparators With/Without Reference MAX917–MAX920 Typical Operating Characteristics (continued)
(VCC = +5V, VEE = 0V, CL = 15pF, VOVERDRIVE = 100mV, TA = +25°C, unless otherwise noted.)
MAX917/MAX919 PROPAGATION DELAY (tPD-) PROPAGATION DELAY (t PROPAGATION DELAY (t PD+) PD-) vs. TEMPERATURE vs. TEMPERATURE vs. CAPACITIVE LOAD
30 140 120 VCC = 1.8V 120 25 V 100 CC = 1.8V MAX917-920 toc19 MAX917-920 toc20 V MAX917-920 toc21 CC = 5V V 100 20 CC = 5V 80 μs) 80 μs) μs) ( VCC = 3V 15 VCC = 3V 60 t PD- t PD+ V 60 CC = 3V t PD- 10 40 40 5 VCC = 1.8V 20 20 VCC = 5V 0 0 0 -40 -15 10 35 60 85 -40 -15 10 35 60 85 0.01 0.1 1 10 100 1000 TEMPERATURE (°C) TEMPERATURE (°C) CAPACITIVE LOAD (nF)
MAX917/MAX919 MAX917/MAX919 PROPAGATION DELAY (tPD+) PROPAGATION DELAY (tPD-) PROPAGATION DELAY (tPD+) vs. CAPACITIVE LOAD vs. INPUT OVERDRIVE vs. INPUT OVERDRIVE
160 70 100 VCC = 3V VCC = 1.8V 90 140 V 60 CC = 5V 80 120 MAX917-920 toc22 MAX917-920 toc23 MAX917-920 toc24 70 VCC = 5V 50 100 60 μs) μs) ( μs) ( VCC = 3V 80 ( 40 50 t PD+ t PD- t PD+ 40 60 VCC = 3V 30 VCC = 5V 30 40 VCC = 1.8V 20 VCC = 1.8V 20 20 10 0 10 0 0.01 0.1 1 10 100 1000 0 10 20 30 40 50 0 10 20 30 40 50 CAPACITIVE LOAD (nF) INPUT OVERDRIVE (mV) INPUT OVERDRIVE (mV)
MAX918/MAX920 MAX918/MAX920 PROPAGATION DELAY (t PROPAGATION DELAY (t PROPAGATION DELAY (t PD-) vs. PD+) vs. PD-) PULLUP RESISTANCE PULLUP RESISTANCE (VCC = 5V)
MAX917-920 toc27 20 250 VCC = 1.8V 19 200 IN+ MAX917-920 toc26 MAX917-920 toc25 (50mV/ 18 div) VCC = 3V 150 VCC = 5V μs) μs) ( 17 t PD- t PD- 100 OUT VCC = 3V 16 (2V/div) VCC = 5V 50 15 VCC = 1.8V 14 0 10 100 1k 10k 10 100 1k 10k 20μs/div R R PULLUP (kΩ) PULLUP (kΩ)
_______________________________________________________________________________________ 7
