Datasheet VOM1271 (Vishay) - 3
ManufacturerVishay
DescriptionPhotovoltaic MOSFET Driver with Integrated Fast Turn-Off, Solid-State Relay
Pages / Page7 / 3 — VOM1271. SAFETY AND INSULATION RATINGS PARAMETER. TEST CONDITION. SYMBOL. …
File Format / SizePDF / 125 Kb
VOM1271. SAFETY AND INSULATION RATINGS PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. TYPICAL CHARACTERISTICS
VOM1271 SAFETY AND INSULATION RATINGS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT TYPICAL CHARACTERISTICS
VOM1271
SAFETY AND INSULATION RATINGS PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Climatic classification (according to IEC 68 part 1) IEC 68 part 1 40/100/21 Comparative tracking index Insulation group IIIa CTI 175 399 Transient overvoltage VIOTM 6000 V Recurring peak voltage VIORM 630 V Package safety power PSO 350 mW Package safety current ISI 150 mA Package safety temperature TSI 175 °C Creepage distance 5 mm Clearance distance 5 mm
(Tamb = 25 °C, unless otherwise specified) 10 12 R = 1 MΩ 9 L 11 8 10 7 (V) 9 I = 10 mA F 6 F . I R = 500 kΩ L (V) s 5 8 I = 30 mA v OC F 4 V OC 7 V 3 6 I = 5 mA 2 F 1 5 0 4 0 5 10 15 20 25 30 35 40 45 50 - 40 - 20 0 20 40 60 80 100 IF (mA) Ambient Temperature (°C) Fig. 2 - Output Open Circuit Voltage vs. LED Current Fig. 4 - Output Open Circuit Voltage vs. Ambient Temperature 60 600 50 500 I = 30 mA F 40 ) 400 s (μ (μA) 30 off 300 CIS , t 20 t on I = 10 mA 200 F ton 10 100 t I = 5 mA off F 0 0 - 40 - 20 0 20 40 60 80 100 0 5 10 15 20 25 30 35 40 45 50 Ambient Temperature (°C) IF (mA) Fig. 3 - Output Short-Circuit Current vs. Ambient Temperature Fig. 5 - ton, toff vs. LED Current Rev. 1.6, 07-Jan-14
3
Document Number: 83469 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
