Datasheet AD8061, AD8062, AD8063 (Analog Devices) - 10
Description | Low Cost, 300 MHz Rail-to-Rail Amplifier (Single with Disable) |
Pages / Page | 20 / 10 — AD8061/AD8062/AD8063. Data Sheet. 1400. VS = ±2.5V. FALLING EDGE. G = +1. … |
Revision | J |
File Format / Size | PDF / 396 Kb |
AD8061/AD8062/AD8063. Data Sheet. 1400. VS = ±2.5V. FALLING EDGE. G = +1. 1200. L = 1kΩ. S = ±4V. 2.5V. 1000. S = +5V. 800. VOUT. E (V/. T A. 600
AD8061/AD8062/AD8063 Data Sheet 1400 VS = ±2.5V FALLING EDGE G = +1 V 1200 IN R V L = 1kΩ S = ±4V 2.5V 1000 FALLING EDGE ) V s S = +5V µ 800 VOUT TS E (V/ L T A VO R 600 RISING EDGE EW VS = ±4V 0V SL 400 RISING EDGE VS = +5V 200 500mV/DIV
028 025 01065-
0
01065-
0 20 40 60 80 100 120 140 160 180 200 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 TIME (ns) OUTPUT STEP (V)
Figure 25. Slew Rate vs. Output Step Amplitude, G = 2, RL = 1 kΩ, VS = 5 V Figure 28. Input Overload Recovery, Input Step = 0 V to 2 V
1k VS = ±2.5V VS = 5V G = +5 R R L = 1kΩ L = 1kΩ V z) OUT H 2.5V 100 V/ (n E TS L OIS N VO VIN 1.0V GE A LT 10 VO 0V
026
500mV/DIV
029
1
01065- 01065-
10 100 1k 10k 100k 1M 10M 0 20 40 60 80 100 120 140 160 180 200 FREQUENCY (Hz) TIME (ns)
Figure 26. Voltage Noise vs. Frequency Figure 29. Output Overload Recovery, Input Step = 0 V to 1 V
100 0 VCM = 0.2V p-p VS = 5V –10 R R L = 100Ω L = 1kΩ V ) –20 S = ±2.5V SIDE 2 Hz –30 A/ 10 (p SIDE 1 E B) –40 IS (d NO –50 RR NT CM –60 604Ω 1 604Ω –70 CURRE 50Ω VIN 154Ω –80 200mV p-p 57.6Ω 154Ω
027
–90
030
0
01065-
–100
01065-
10 100 1k 10k 100k 1M 10M 0.01 0.1 1 10 100 500 FREQUENCY (Hz) FREQUENCY (MHz)
Figure 27. Current Noise vs. Frequency Figure 30. CMRR vs. Frequency Rev. J | Page 10 of 20 Document Outline Features Applications Connection Diagrams General Description Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Typical Performance Characteristics Circuit Description Headroom Considerations Overload Behavior and Recovery Input Output Capacitive Load Drive Disable Operation Board Layout Considerations Applications Information Single-Supply Sync Stripper RGB Amplifier Multiplexer Outline Dimensions Ordering Guide
