Datasheet AD8603, AD8607, AD8609 (Analog Devices)
Description | Precision Micropower, Low Noise CMOS, Rail-to-Rail Input/Output Operational Amplifiers |
Pages / Page | 16 / 1 — Precision Micropower, Low Noise CMOS,. Rail-to-Rail Input/Output … |
Revision | C |
File Format / Size | PDF / 453 Kb |
Precision Micropower, Low Noise CMOS,. Rail-to-Rail Input/Output Operational Amplifiers. AD8603/AD8607/AD8609. FEATURES
Precision Micropower, Low Noise CMOS, Rail-to-Rail Input/Output Operational Amplifiers AD8603/AD8607/AD8609 FEATURES PIN CONFIGURATIONS Low offset voltage: 50 μV maximum OUT 1 5 V+ Low input bias current: 1 pA maximum AD8603 V– 2 TOP VIEW Single-supply operation: 1.8 V to 5 V (Not to Scale)
1
Low noise: 22 nV/√Hz
00
+IN 3 4 –IN
6- 35
Micropower: 50 μA maximum
04 Figure 1. 5-Lead TSOT (UJ Suffix)
Low distortion No phase reversal Unity gain stable OUT A 1 8 V+ AD8607 –IN A 2 7 OUT B TOP VIEW +IN A 3 6 –IN B
2
(Not to Scale) APPLICATIONS
00 6-
V– 4 5 +IN B
35 04
Battery-powered instrumentation
Figure 2. 8-Lead MSOP (RM Suffix)
Multipole filters Sensors OUT A 1 8 V+ Low power ASIC input or output amplifiers –IN A 2 AD8607 7 OUT B +IN A 3 TOP VIEW 6 –IN B
3 00
(Not to Scale)
6-
V– 4 5 +IN B GENERAL DESCRIPTION
35 04 The AD8603/AD8607/AD8609 are single/dual/quad micro- Figure 3. 8-Lead SOIC (R Suffix) power rail-to-rail input and output amplifiers, respectively, that feature very low offset voltage as well as low input voltage and
OUT A 1 14 OUT D
current noise.
–IN A 2 13 –IN D
These amplifiers use a patented trimming technique that achieves
+IN A 3 AD8609 12 +IN D TOP VIEW
superior precision without laser trimming. The parts are fully
V+ 4 11 V– (Not to Scale)
specified to operate from 1.8 V to 5.0 V single supply or from
+IN B 5 10 +IN C
±0.9 V to ±2.5 V dual supply. The combination of low offsets, low
–IN B 6 9 –IN C
4 00 noise, very low input bias currents, and low power consumption
OUT B 7 8 OUT C
6- 35 04 makes the AD8603/AD8607/AD8609 especially useful in portable Figure 4. 14-Lead TSSOP (RU Suffix) and loop-powered instrumentation. The ability to swing rail to rail at both the input and output
OUT A 1 14 OUT D
enables designers to buffer CMOS ADCs, DACs, ASICs, and
–IN A 2 13 –IN D
other wide output swing devices in low power, single-supply
+IN A 3 12 +IN D AD8609
systems.
V+ 4 TOP VIEW 11 V– (Not to Scale) +IN B 5 10 +IN C
The AD8603 is available in a tiny 5-lead TSOT package. The
–IN B 6 9 –IN C
AD8607 is available in 8-lead MSOP and 8-lead SOIC packages. 5
OUT B 7 8 OUT C
-00 56 The AD8609 is available in 14-lead TSSOP and 14-lead SOIC 43 0 packages. Figure 5. 14-Lead SOIC (R Suffix)
Rev. C Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2003–2008 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS NO PHASE REVERSAL INPUT OVERVOLTAGE PROTECTION DRIVING CAPACITIVE LOADS PROXIMITY SENSORS COMPOSITE AMPLIFIERS BATTERY-POWERED APPLICATIONS PHOTODIODES OUTLINE DIMENSIONS ORDERING GUIDE
