Datasheet CD4013B (Texas Instruments) - 7
ManufacturerTexas Instruments
DescriptionCMOS Dual D-Type Flip-Flop
Pages / Page28 / 7 — CD4013B. www.ti.com. Electrical Characteristics: Static (continued). …
RevisionE
CD4013B. www.ti.com. Electrical Characteristics: Static (continued). PARAMETER. TEST CONDITIONS. MIN. TYP. MAX. UNIT
CD4013B www.ti.com Electrical Characteristics: Static (continued) PARAMETER TEST CONDITIONS MIN TYP MAX UNIT
CD4013B www.ti.com
SCHS023E – NOVEMBER 1998 – REVISED SEPTEMBER 2016
over operating free-air temperature range (unless otherwise noted)
T V A = –55°C, –40°C, O = 0.5 or 4.5, VDD = 5 1.5 25°C, 85°C, and 125°C T V A = –55°C, –40°C, ILmax Input low voltage V 3 V O = 1 or 9, VDD = 10 25°C, 85°C, and 125°C VO = 1.5 or 13.5, TA = –55°C, –40°C, 4 VDD = 15 25°C, 85°C, and 125°C T V A = –55°C, –40°C, O = 0.5 or 4.5, VDD = 5 3.5 25°C, 85°C, and 125°C T V A = –55°C, –40°C, IHmin Input high voltage V 7 V O = 1 or 9, VDD = 10 25°C, 85°C, and 125°C VO = 1.5 or 13.5, TA = –55°C, –40°C, 11 VDD = 15 25°C, 85°C, and 125°C TA = –55°C ±0.1 TA = –40°C ±0.1 IINmax Input current VIN = 0 or 18, VDD = 18 T µA A = 25°C ±10–5 ±0.1 TA = 85°C ±1 TA = 125°C ±1
6.6 Electrical Characteristics: Dynamic
at TA = 25°C, input tr, tf = 20 ns, CL = 50 pF, RL = 20 kΩ (unless otherwise noted)
VDD = 5 150 300 tPHL, Propagation delay time, V ns t DD = 10 65 130 PLH clock to Q or Q outputs VDD = 15 45 90 VDD = 5 150 300 tPLH Set to Q or reset to Q V ns DD = 10 65 130 VDD = 15 45 90 VDD = 5 200 400 tPHL Set to Q or reset to Q V ns DD = 10 85 170 VDD = 15 60 120 VDD = 5 100 200 tTHL, Transition time V ns t DD = 10 50 100 TLH VDD = 15 40 80 VDD = 5 3.5 7 fCL Maximum clock input frequency(1) V MHz DD = 10 8 16 VDD = 15 12 24 VDD = 5 70 140 Minimum clock pulse width V ns DD = 10 30 60 VDD = 15 20 40 tW VDD = 5 90 180 Minimum set or reset pulse width V ns DD = 10 40 80 VDD = 15 25 50 VDD = 5 20 40 tS Minimum data setup time V ns DD = 10 10 20 VDD = 15 7 15 tH Minimum data hold time VDD = 5, 10, 15 2 5 ns (1) Input tr, tf = 5 ns Copyright © 1998–2016, Texas Instruments Incorporated Submit Documentation Feedback 7 Product Folder Links: CD4013B Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics: Static 6.6 Electrical Characteristics: Dynamic 6.7 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.3 Application Curve 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Documentation Support 11.1.1 Related Documentation 11.2 Receiving Notification of Documentation Updates 11.3 Community Resources 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Mechanical, Packaging, and Orderable Information
