Datasheet CD4013B (Texas Instruments) - 8
ManufacturerTexas Instruments
DescriptionCMOS Dual D-Type Flip-Flop
Pages / Page28 / 8 — CD4013B. www.ti.com. Electrical Characteristics: Dynamic (continued). …
RevisionE
CD4013B. www.ti.com. Electrical Characteristics: Dynamic (continued). PARAMETER. TEST CONDITIONS. MIN. TYP. MAX. UNIT
CD4013B www.ti.com Electrical Characteristics: Dynamic (continued) PARAMETER TEST CONDITIONS MIN TYP MAX UNIT
CD4013B
SCHS023E – NOVEMBER 1998 – REVISED SEPTEMBER 2016
at TA = 25°C, input tr, tf = 20 ns, CL = 50 pF, RL = 20 kΩ (unless otherwise noted)
VDD = 5 15 trCL, Clock input rise or fall time V µs t DD = 10 10 fCL VDD = 15 5 CIN Input capacitance Any input 5 7.5 pF
6.7 Typical Characteristics
40 20 Gate-to-Source Voltage = 5 V Gate-to-Source Voltage = 5 V ) 35 Gate-to-Source Voltage = 10 V ) 17.5 Gate-to-Source Voltage = 10 V Gate-to-Source Voltage = 15 V Gate-to-Source Voltage = 15 V (mA 30 (mA t 15 ren urrent 25 ur 12.5 C ) C nk 20 nk) 10 Si (Si 15 ow ( 7.5 t Low t L u pu 10 5 utp Out O 5 2.5 0 0 0 5 10 15 20 25 0 5 10 15 20 25 Drain-to-Source Voltage (V) Drain-to-Source Voltage (V) D001 D002
Figure 1. Typical Output Low (Sink) Current Figure 2. Minimum Output Low (Sink) Current
0 0 Gate-to-Source Voltage = -5 V Gate-to-Source Voltage = -5 V ) -5 Gate-to-Source Voltage = -10 V Gate-to-Source Voltage = -10 V (mA Gate-to-Source Voltage = -15 V (mA Gate-to-Source Voltage = -15 V t t -10 -5 ren ren ur ur C -15 C rce) -20 rce) -10 ou ou S S h ( -25 h ( ig ig t H t H u -30 u -15 utp utp O -35 O -40 -20 -25 -20 -15 -10 -5 0 -25 -20 -15 -10 -5 0 Drain-to-Source Voltage (V) Drain-to-Source Voltage (V) D003 D004
Figure 3. Typical Output High (Source) Current Figure 4. Minimum Output High (Source) Current
8 Submit Documentation Feedback Copyright © 1998–2016, Texas Instruments Incorporated Product Folder Links: CD4013B Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics: Static 6.6 Electrical Characteristics: Dynamic 6.7 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.3 Application Curve 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Documentation Support 11.1.1 Related Documentation 11.2 Receiving Notification of Documentation Updates 11.3 Community Resources 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Mechanical, Packaging, and Orderable Information
