Datasheet TL081, TL081A, TL081B, TL082, TL082A, TL082B, TL084, TL084A, TL084B (Texas Instruments) - 10
Manufacturer | Texas Instruments |
Description | TL08xx JFET-input operational amplifier |
Pages / Page | 51 / 10 — TL081. , TL081A,. TL081B. , TL082,. TL082A. TL082B. , TL084,. TL084A. , … |
Revision | I |
File Format / Size | PDF / 2.5 Mb |
TL081. , TL081A,. TL081B. , TL082,. TL082A. TL082B. , TL084,. TL084A. , TL084B. www.ti.com. L = 10 kΩ. 15 V. RL = 2 kΩ. 12.5. A = 25. See Figure 2. lta
TL081 , TL081A, TL081B , TL082, TL082A TL082B , TL084, TL084A , TL084B
SLOS081I – FEBRUARY 1977 – REVISED MAY 2015
www.ti.com
15
15 R V L = 10 kΩ V CC
15 V V − RL = 2 kΩ − T e
12.5 A = 25
C e
12.5 g See Figure 2 g R lta lta L = 2 kΩ o o t V t V u
10 u
10 tp tp u TA = −55
C u k O k O a
7.5 a
7.5 e e m P m P u T u A = 125
C im
5 im
5 x x a a M M − − M
2.5 M
2.5 O OM O V OM CC
15 V V V See Figure 2 0 0 −75 −50 −25 0 25 50 75 100 125 10 k 40 k 100 k 400 k 1 M 4 M 10 M f − Frequency − Hz TA − Free-Air Temperature −
C Figure 4. Maximum Peak Output Voltage Figure 3. Maximum Peak Output Voltage vs vs Free-Air Temperature Frequency
15
15 V R CC
15 V V V L = 10 kΩ − T T A = 25
C − A = 25
C e
12.5 See Figure 2 e
12.5 g g lta lta o o t V t V
u 10 u
10 tp tp u u k O k O a
7.5 a
7.5 e e m P m P u u
im 5 im
5 x x a a M M − −
2.5 M M
2.5 O OM O OM
8
V
8
V 0 0 0.1 0.2 0.4 0.7 1 2 4 7 10 0 2 4 6 8 10 12 14 16 R |V L − Load Resistance − kΩ CC
| − Supply Voltage − V Figure 6. Maximum Peak Output Voltage Figure 5. Maximum Peak Output Voltage vs vs Supply Voltage Load Resistance 1000 106 VCC
5 V to
15 V 400 RL = 2 kΩ l l 105 TA = 25
C tia V 200 tia n n /m re V re − 100 iffe 104 0 iffe
n Differential ift h l D l D a tio Voltage a n a e S 40 n Amplification s ig ig 103 45 a lific
-S h p -S e Amplification e P m 20 e rg A rg g a a L e L lta g 10 102 90
− o – V lta o VD V VD AA 4 Phase Shift V A CC
15 V A 135 101
VO =
10 V 2 RL = 2 kΩ 1 1 180
−75 −50 −25 0 25 50 75 100 125 1 10 100 1 k 10 k 100 k 1 M 10 M T f − Frequency − Hz A − Free-Air Temperature −
C Figure 8. Large-Signal Differential Voltage Amplification and Figure 7. Large-Signal Differential Voltage Amplification Phase Shift vs vs Free-Air Temperature Frequency
10 Submit Documentation Feedback Copyright © 1977–2015, Texas Instruments Incorporated Product Folder Links: TL081 TL081A TL081B TL082 TL082A TL082B TL084 TL084A TL084B Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for TL08xC, TL08xxC, and TL08xI 6.6 Electrical Characteristics for TL08xM and TL084x 6.7 Operating Characteristics 6.8 Dissipation Rating Table 6.9 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Total Harmonic Distortion 8.3.2 Slew Rate 8.4 Device Functional Modes 9 Applications and Implementation 9.1 Application Information 9.2 Typical Applications 9.2.1 Inverting Amplifier Application 9.2.1.1 Design Requirements 9.2.1.2 Detailed Design Procedure 9.2.1.3 Application Curve 9.3 System Examples 9.3.1 General Applications 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Examples 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Community Resources 12.4 Trademarks 12.5 Electrostatic Discharge Caution 12.6 Glossary 13 Mechanical, Packaging, and Orderable Information
